Turbo under boost / mechanical fault exists in charge air bypass flap
Old May 24, 2023 | 06:13 PM
defender902014's Avatar
c220 w205
Hey guys first post go easy on me 😅
got an issue with my 2017 220d w205
It’s under powered and then then goes into limp mode but doesn’t always put the eml on..
Seems to stutter a little around low rpm as it starts to build boost/revs up
pluged it in and I get
p2206100 mechanical fault exists in charge air bypass flap
also had a code for turbo underboost
I’ve replaced the Engine Turbocharger Pressure Transducer A0001531700
As advised by a friend but to no avail It’s still going into limp mode
has anybody had this befor or could anyone point me in the right direction Where to look next ? Don’t want to keep firing the parts cannon at it
thanks
Old Apr 21, 2024 | 11:01 AM
Mhnd_bnz's Avatar
W205
I have the same problem. Has anyone found a solution please?
Old Nov 21, 2025 | 02:35 PM
renka's Avatar
thanks
Have you found the problem?
