C300 2.0l W205 Catastrophic Noise? Help identifying Knock.
Drain the oil and pull the filter, check for shrapnel. Compression test. Don't drive or start the car anymore so that saving the engine block is on the table if you want to replace the cracked piston if thats what it ends up being.. If you're under warranty or youre the first owner start making phone calls.
I could also completely be wrong about this.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
It's like oh we're the approved factory fill for Porsche so we're the best. Ok then why does 15% of my oil fill end up in the atmosphere?
yea i know, i've seen it in the shop. people actually break down and cry it's really sad.
The industry knows about LSPI and everybody is like ok theres an API SP to address timing chain wear, LSPI, but then now theres API SN PLUS spec that REALLY fixes this time and supercedes it. Suddenly, and all the existing oils are like YUP ME TOO and it's like... then how tf do we know about LSPI, timing chain wear, spark knock, turbocharger wear then if all the oils on the market are hunky dory and full synthetic and super great and completely unchanged from like 20 years ago?
