GLC 300 Engine failure
I also used consumer reports before buying a 2019 CPO GLC300. Seems like they captured the earlier 2016 wrist pin issues in their reliability ratings.
As for all M274s, I am curious what % of all GLC300s will actually get a cracked piston? If it's a lot, then yeah I don't understand the discrepancy. in the Consumer reports rating.
As you stated yourself: "I am curious what % of all GLC300s will actually get a cracked piston?" And this engine is not only used on the GLC, so one should ask how many of these M274 engines have the failure? Can you imagine how many of these engines are installed on cars all over the world? A few isolated cases do not make it a piece of crap, even though many here do think so.
As mentioned before, there is no such thing as a bullet proof car/engine, and one needs to maintain it and treat it correctly with oil change intervals, using the correct gasoline, etc.
No Honda or Toyota will run forever if one does not change the oil, ............................ just saying.
I believe gasoline quality and spec discrepancies are the biggest cause of these pre ignition/detonation failures reported sporadically on MULTIPLE manufacturer internet message boards like mbworld.com
These modern 4 cylinder engines (all brands) are pushing the performance and efficiency envelope, thereby reducing the engineering margin of safety.
I'm not sure I'd call them overstressed, though.
Progress in managing flame fronts, spark plug and combustion chamber design, have reduced instantaneous loads, and it's possible that they are reduced in important parts of the cycle.
Improved oils, hollow crank lubrication improvements, 48v cooling, metallurgy - all that modern stuff, may make these engines less stressed than 245hp out of the 87 Buick GNX's 3.6 liters. Or 282hp out of the terrorizing 78 930 Turbo's 3.0.
There must be a limit, I suppose, but I can't guess where it is.
MB is clearly just trying to get though the warranty period. Its a financial decision as thats the cheaper way to go for them. That doesnt mean its not a real problem.
Well I just did my trans service at my trusted independant shop who has a former Mercedes tech. His words when I asked him his opinion on the motor. "well I can tell you I changed alot of motors in that generation truck" !!!! He said its a real problem, he wouldnt own one. Thats one tech in one dealership with only that exposure....think about that. Think about what we dont know. Everyone who owns a MB is not an enthusiast or on a forum. This can be an echo chamber. But my techs experience speaks volumes.
There are known issues with many manufactures. Just because it didnt happen or happen yet doesnt mean it wont. Where there is smoke there is fire.
I had an E46 M3..........Huge SMG trans problem with that generation. Great car in 100 ways...but there is no denying the issue. Mileage got higher more SMG reports. It took many years for it to BE KNOWN. The same is happening here. Why people deny something because it isnt presently happening to them I dont know. Will they come back if it happens and say I was wrong??
The internet states that just in the US, last year MB sold 51,805 GLC‘s, and that is in the US alone. So since the model came out, and we consider the somewhat same trend for all the years, that would be at least 250,000 cars. How many you think that is worldwide, and what percentage do you think shall fail?
How many motors are “a lot” that your mechanic changed? 5? 20, 50???? And I say it again as stated many times before, was the vehicle properly maintained and treated, did someone pull it out of the garage and kicked the snot out of it while it was ice cold, was high octane gasoline used, ……… etc., blah, blah, blah.
You are correct, we will never know.
Previous generations had the balance shaft issue. Did every engine fail, or some?
Funny thing is, I know a MB Mechanic who is still actively working at MB, he acknowledges the problem as it does exist, but feels it’s blown way out of proportion.
Will you come back if nothing happens to you and tell me I was wrong?
I think we can continue to play this game for a very long, long time. Go buy a Lexus.
"The SN PLUS Service Category was introduced as a supplement to API SN specification in 2018 to mitigate low speed pre-ignition (LSPI) events in Turbocharged Gasoline Direct Injection (TGDI) engines. Such LSPI events can cause engine knocking, decreased efficiency, and in the worst case, catastrophic failure due to cracked pistons."
So, an entirely new API oil formulation was developed (with some urgency) specifically to address the cracked piston issue on TGDI engines. Neither the API nor the PQIA mention MB because this problem exists for ALL small-displacement, high output TGDI engines. We can debate endlessly about the issue as it relates to MB (this is an MB site after all), but to attribute the problem specifically and exclusively to MB is totally inaccurate and misleading. A quick scan of other forums will confirm that Audi, Volvo, GM, BMW and others using small displacement TGDI engines are encountering similar cracked piston/broken piston ring issues.
You just want and hope that everyone agrees with your opinion. Well, unfortunately not. You know why, ……… “kinda what forums are for”. SMH!
Hearsay? Definitely.
Liar? No.
Useful information? No
Able to answer follow-up questions? No.
Attacking multiple posters instead of answering multiple requests/comments doesn't make your tale more believable.
Try answering the questions. That usually helps.
Liar? No.
Liar? No.
Diagnosis thus far is that Cylinder 1 Piston is cracked. Codes I was able to catch after the engine would no longer start and the check engine light was displayed. I had a OBD2 reader lying around after doing work on a friends car. Downloaded the full license for my car.
P030085 Combustion misfiring has been detected.
P030185 Combustion misfiring of cylinder 1 has been detected.
P030285 Combustion misfiring of cylinder 2 has been detected.
P030385 Combustion misfiring of cylinder 3 has been detected.
I had been on the road for less that 4 mins, when the car lost all power while accelerating from 40km - 70km. Prior to this no warning indicators had been displayed in the dashboard instrument cluster, no warnings were even displayed when the engine failed.
The vehicle is 90% driven within the CBD and surrounding suburbs within 15km.
During the last 6 months it is primarily driven in comfort mode due to increasing petrol costs.
The vehicle always receives premium petrol being Shell V-Power 98 (90% of the time) and BP Ultimate Unleaded 98 (10% the remainder) with no additional performance additives.
The vehicle is well serviced, very well maintained, in exceptional overall condition.
The never put under load or driven above 3800 rpm unless at operating temperature of approx. 95. deg C.Other premature failures include.
Exhaust Camshaft magnet o-ring failed @ 9,893 KM
Alternator Belt Pulley bearing Leaking leaking likely much before 10,688 when I picked it up.
Ticking noise on Cold Start at reported @ 4,425 Km which would remain until the engine had warmed.
I will be pursuing a claim with Mercedes Benz Australia under Lemon Laws and seek an entire engine replacement.
Whist my car is approx. 9 months outside of MB 2 year manufacture warranty Australian Consumer Law, specifically Consumer Guarantees for products stipulate all Australian businesses must provide a set of "automatic guarantees" regardless of standard manufacture warranties given or sold.
Shortly after agreeing to repair my car they advised they needed to replace the engine (also at their expense). A courtesy car was included the same day as they began their works. Not a sorry or anything of the kind when I picked it up, it did not even get the standard car wash.
What now annoys me is that what I thought was a "New Engine" is in fact just a "Long Block (in which the entire crank assembly including the cylinder head, valves, injection and much more have been completely overhauled and installed using only MB Genuine Parts), compared to a New Engine or New Basic Engine or Basic Engine or Long Block Plus. In short Long Block replacements are a “remanufactured engine” that does not get tested on the manufactures test stand before been sent to the dealership. You can learn more about that at b2bconnect.mercedes-benz.com/gb/products/remanufactured-parts/cars/engines/basic-engine
Even more annoying is that the this Long Block from the "new engine number” 454,306 provided appears to have been produced 86,479 before my failed engine “540,758" OR approx. 47,704 after MB modified their faulty wrist pins that were installed as of engines in 2015 engine number 274 920 30 406 602 on which leads me to believe this engine may have been produced in 2016-2017 ??
Someone please correct me if my understanding about the engine number is incorrect.
Anyway its now been 5 months and with 2,002 km on the engine and is already more noisey on cold starts that the original engine. Transmission also notably louder. I don’t know what to do, I just know I don’t trust this engine, or MB and I will never buy another MB again. Is it all in my head or should I flick it.
If you are interested in what a new m274 long block sounds like with 2,002 km you can download my videos at recorded on a iPhone 101a M274 2018 Cold Start 3m 30sec - 37-40 deg celsius.mov
https://www.icloud.com/iclouddrive/0...40_deg_celsius
1b M274 2018 Cold Start 35 secs - Bottom Engine Bay + SLOWMO.zip
https://www.icloud.com/iclouddrive/0...e_Bay_+_SLOWMO
1c M274 2018 Cold Start 10 secs at 50 70 80 95 96 deg celsius 4-10.zip
https://www.icloud.com/iclouddrive/0...g_celsius_4-10
No warranty was offered on the new long block as it was done under warranty.MB also returned it with a broken PVC line (crank case vent line) and a torn aftermarket pod air filter. Fortunately as soon as I drove it the 2k drive home I inspected their workmanship. Had I not caught this vent line it would not have been too long before I was back for another engine replacement.
New Engine Number : Teil-Nr is the Long Block part number
