Strong jerk when accelerating
Old Jul 30, 2023 | 10:09 AM
QLMAN_PL's Avatar
W205
I have a problem with Mercedes w205 c200 year 2016 petrol 4x4.
In my case, jerking occurs very rarely, but usually when I press the gas pedal hard. Strong jerk sometimes two. Audible hit. The effect on the automatic and manual gear shift mode. I checked whether the effect occurs when dropping the gear.
A moment later I can trample as much as I want and everything is fine. The engine turns on beautifully and gives off power.
The car at idle and calm driving works properly. Evenly and quietly. No errors on OBD2.
With hard driving, no problems for weeks. The car accelerates properly. Nothing happens until it's just...YEP! A strong jerk and a sudden drop in power for 1/2 second and a moment later it's OK.
I replaced a damaged pear from the turbine. What's next?
I changed the oil in the gearbox. There is jerking when pressing hard. The revs drop when you jerk. If I do not let go of the gas, it happens that the gearbox switches to D mode and cannot be changed to Manual. I've been in higher gears ever since. No power. WTF!The dealerships don't know what's causing it. The car was connected to the computer. ZERO errors.
Old Jul 31, 2023 | 03:53 AM
megb's Avatar
C250
Smile
Maybe this will help!
Old Aug 1, 2023 | 02:10 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
What scanner model are you trusting to help troubleshoot?
Use the scanner to read/graph fuel pressure when engine is acting up.
Old Sep 30, 2023 | 08:58 PM
QLMAN_PL's Avatar
W205
that was the problem
Old Oct 8, 2023 | 04:55 PM
W205C43PFL's Avatar
Surprised they didn't find any errors/codes, as PO33904 is a code.
Old Nov 3, 2023 | 03:37 PM
p.sam118's Avatar
2015 C300 4Matic
I had this issue recently and was traced back to crankshaft issue as well (and pedal value sensor malfunction). So many sensors smh!!!!
Old May 5, 2024 | 07:46 PM
Elchin Lat's Avatar
C class 2.0
Hi - have you managed to fix this?
Old May 5, 2024 | 10:56 PM
p.sam118's Avatar
2015 C300 4Matic
Hi there, are you facing the same problem? I faced a similar issue in the fall and fixed it by getting my crankshaft position sensor (primary issue) and pedal value sensor replaced. HAven't had any issues since.
Old May 6, 2024 | 12:16 AM
hard faults... don't go quietly
Originally Posted by p.sam118
Hi there, are you facing the same problem? I faced a similar issue in the fall and fixed it by getting my crankshaft position sensor (primary issue) and pedal value sensor replaced. Haven't had any issues since.
both of these will register a CEL show-stopping or limp-mode fault.
These faults are classified with top severity by ECU:
-- CKP stops the engine dead
-- APP limp-modes at the very first occurrence.
Normal driving is interrupted with this class of hard faults.
Zero chance of both defective parts at the same time.
