C200 OM626 oil leak
Old Sep 29, 2023 | 02:37 PM
Istrijan's Avatar
W205 C200
C200 OM626 oil leak
C200 1.6 136hp OM626 engine 9/2016; Today found traces of severe oil leak on top engine. Oil seems to leak from rubber pipe connection on the left side, connected with the air exhaust pipe. No warning on display. Presently in a remote zone without service available. Anyone any hint? Thanks!
Old Oct 8, 2023 | 08:40 PM
Cata's Avatar
w209
Did you solved it? What was it?
Old Dec 4, 2023 | 12:55 PM
ak-mb's Avatar
W205
Hello,
i am having the same issue.
Did you solved it?
How?
best regards
Old Dec 18, 2023 | 07:39 AM
Pg0391's Avatar
W205 business
check the oil vapor pipe, it would be the one that goes into the suction pipe if it is not loose, I solved the problem with a cable tie
Old Oct 24, 2024 | 04:21 PM
ali147's Avatar
Hey did you find the solution, I’m also facing the same issue ?
Originally Posted by ak-mb
Hello,
Did you solved it?
How?
best regards
Old Oct 24, 2024 | 04:22 PM
ali147's Avatar
Hey where is that pipe, can you share a picture ?
