Passenger Side Heater Not Working
Hi!
Cold air coming from the passenger side vents when the heater is on. It only blows hot air in the driver side. Any advices? (Already played with the controls with no results... Changed setting to manual, temp setting to LO and then to HI several times but it continues with the problem)
Forgot to add this info: W205... 2015 C300 4Matic ... No hot air coming from passenger side. Heater works fine in the driver side. My iCarsoft MBII scanner only shows code P06DA00... Any Advice will be appreciated!...
