Change radio frequnecy from Japan to Malaysia?
Old Feb 24, 2024 | 01:12 AM
Corollaaltis's Avatar
2017 C180
I have an imported pre-facelift W205 from japan. Its radio only goes till 90MHz, which means there's only a handful of available radio stations. Anyone know how I can access frequencies above 90MHz? I've looked around and found that there's a supposed "engineering mode" that has an option to switch radio frequencies, but I don't have the expensive software and the technical know-how to do it. I'd still be willing to try it though.
If it helps the Head Unit is COMAND NTG5.5.
Old Jul 8, 2024 | 03:42 PM
Onechocs's Avatar
w205
Hi. Did you get this fixed. Any links will be highly appreciated. TIA
Old Jul 9, 2024 | 01:51 AM
2017 C180
Hi, unfortunately I haven't found a fix. Though I'm planning to take it to a coder when I'm going to the city centre, since my area doesn't have any coders that I know of.
The only other way to get local radios is to use the built in internet radio, which not only has local stations but also stations around the world. (It needs internet, but its better than nothing)
