eco start/stop does not work
Old Mar 2, 2024 | 11:45 PM
Reziko1992's Avatar
c240-w203
Question eco start/stop does not work
hello, i have 2017 c300, when i press eco start/stop button, it is green A on the button, but never shows green or yello A on the dash and the car never turns off when stopped.
the car has a good battery, also no error codes.
has anyone had a similar situacion and how fix?
Old Mar 3, 2024 | 12:07 AM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Unless something has changed, the default for the stop/start is on. When you press the button, you are turning it off. Start the car and don’t touch the button. Unless you want to turn it off.
Old Mar 3, 2024 | 04:33 AM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
how do you know you have a good battery?
when did you last change it?
and is it AGM battery?
Old Mar 3, 2024 | 04:45 AM
Reziko1992's Avatar
c240-w203
there is not any notification on the dash, that battery is low, there is 2022 mercedes oem battery AGM
Old Mar 3, 2024 | 04:47 AM
Reziko1992's Avatar
c240-w203
i made a video
Old Mar 3, 2024 | 04:48 AM
Reziko1992's Avatar
c240-w203
nothing has changed
Old Mar 3, 2024 | 12:20 PM
Ok, It’s on. Must be short trips and not warmed up. You confused me when you said that you pressed the button. You usually do that to turn it off.
Old Mar 4, 2024 | 08:58 AM
Cosworth2000's Avatar
2022 E53 AMG
Nothing seems wrong.. it maybe cause it's only 8 degree outside and you have your temperature on HI setting. Wait until the weather get's warmer to see if the problem remains to exist.
