Constantly getting low battery fob warning
Old Apr 7, 2024 | 09:56 PM
TwoC400s's Avatar
2015 C400 4MATIC Palladium Silver Metallic
My 2015 C400 gives me low Key fob battery warnings no matter what I do. I've checked both the battery that was in the fob (3.0V) and the new battery (3.3V) with a multi-meter. So the batteries are obviously good, what could be causing the car to think they're low?
Old Apr 14, 2024 | 05:32 PM
KingsoverQueens's Avatar
2013 S550
getting the same thing with both of my fobs, comes back on after about a week after the battery was replaced.
Old Apr 17, 2024 | 08:19 PM
Jack Olsen's Avatar
Same here -- but intermittently. A quick Google search shows this guy's fix:
There is also a reset procedure for the fob:
  1. Put the key in the ignition. Do not start the car.
  2. Quickly remove it within 10 seconds and hold down the Lock button.
  3. While holding the Lock button, press Unlock five times.
  4. Release these buttons and press the Trunk button once. This should synchronize your remote.
Three other possible fixes:
A: Get in car - remove keyless go button - start car with key - turn off car - replace keyless button - takes 2 presses to re-start.
B:
1. Start car with key in the ignition
2. Turn off car and remove key from ignition
3. Start car with the Keyless go button on the transmission shifter
4. Turn off car.
5. Repeat 3 and 4.
C:
1. Set in the car with FOB and close the door.
2. Open FOB and remove the battery
3. Install the new fresh battery in FOB
4. Start the car
5. Turn off car.
6. All done
I'm going to print this out and try one at a time until it (hopefully) fixes the problem.
Old Apr 17, 2024 | 10:15 PM
Jack Olsen's Avatar
Well, I just tried all of the above, including this new AI-generated fix:
To reset the "Replace Key Battery" message on a Mercedes W205 after replacing the key fob battery, follow these steps:
  1. Remove the old battery from the key fob and insert the new battery correctly.
  2. Get inside the vehicle with the key fob and close all doors.
  3. Press the start/stop button once without starting the engine.
  4. Remove the key fob from the vehicle and wait 5-10 minutes outside the vehicle's range.
  5. Return to the vehicle, enter with the key fob, and start the engine normally.
I also tried alternating my two fobs, as well as both CR2025 and CR2032 batteries (both lithium 3v, different thicknesses) in each. No difference.
Here's what I think. I believe this is a problem that grows progressively worse, but it's intermittent initially -- so a 'fix' seems to work for some people, initially (it did for me) -- that's a symptom of the intermittent nature of the problem.
I think the real problem is probably a gradual failure of whatever antenna is receiving the signal from the fobs.
So, the key question: Does anyone know where the receiver is for the signal from the fob?
Old Apr 18, 2024 | 09:02 PM
TwoC400s's Avatar
https://youtu.be/onGQliWZZ0I?si=17Bwwu5coAoZ3gCz
B:
4. Turn off car.
5. Repeat 3 and 4.
C:
4. Start the car
5. Turn off car.
6. All done
I tried what's in the video and the remote "reset procedure" today with no luck.
Does anyone know what the frequency of the keyless go transmission is? I believe the unlock and lock signals are on 315mhz, but what signal does the keyless go use?
Old Apr 20, 2024 | 11:07 AM
Jack Olsen's Avatar
That's a great question.
Ideally, we'd be able to identify the whole process that's taking place from the fob's transmission, to the receiver/antenna (I think it's behind the rear seat), to whichever electronic unit is processing it. I haven't dug up my code reader -- but is there any kind of code thrown for this condition? Do W205s without Keyless Go also have the fob's battery monitored?
As a hail-mary idea, I've got a replacement antenna on the way.
Old Apr 21, 2024 | 05:27 PM
TwoC400s's Avatar
The antenna inside the car? What is the part #?
Old Apr 22, 2024 | 01:16 PM
Jack Olsen's Avatar
Behind the rear seat, I believe.
Keyless Entry Antenna - 205-905-30-05
Old Apr 23, 2024 | 12:33 AM
Jack Olsen's Avatar
Well, I did some experimenting while I wait for the new antenna -- and it appears as though I've solved it. For my car, at least.
I ordered a pair of official Mercedes Parts batteries. It turns out they're "Panasonic Industrial" batteries. Of course, all CR2025 batteries conform to the same specs -- they're lithium manganese dioxide batteries that produce 3 volts (+/- 10%). The Industrial label appears to only mean it's from the Panasonic division that sells batteries to industry in bulk.
But here's the surprise: the Mercedes/Panasonic battery immediately made the message go away. I switched back to my spare fob (Maxell battery), and the message came back.
Could Mercedes be doing something to the batteries? I went out and got some off-the-shelf Panasonic batteries (both CR2025 and CR2032) -- and they also work.
So it's not 'Mercedes,' and it's not 'Industrial.' It's just the Panasonic brand, apparently. My Maxell (Japan) and Energizer (China) batteries produce the error message. But Panasonic (formerly Japan, now Indonesia) do not.
So it appears as though it's just the Panasonic brand that makes the difference.
Some more googling showed that this is also a problem in the BMW community, and Panasonic is what they've discovered there as well.
I'm still suspicious. I can't come up with a reason why one battery would work and another with the same specs would not. But I've gone back and forth with other brands now, and Panasonic is the only one that's working.
Not sure what I'll do with that antenna.
Also weird, and worth noting: the Mercedes Panasonic battery showed 3.23v, Panasonic-only branded was 3.28v, and a random Energizer in my drawer tested at 3.32v. So it's not simply voltage that's triggering the system.
Old Apr 27, 2024 | 11:04 AM
TwoC400s's Avatar
Well, I can't really come up with a rational explanation for it, but the Panasonic battery solved the issue.
So far I'm at 3 days with no low battery warning.
Old Sep 5, 2024 | 01:01 PM
DCF's Avatar
DCF
13 SL63, 07 SL550, 16 Escalade, 11 C70
Same message 'Replace Key Battery' with both fobs in my SL63 even after replacing the batteries. I though it was a problem with the antenna also but ordered some Panasonic batteries and that fixed both fobs. Go figure....
Old Sep 5, 2024 | 01:32 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I found (in my bikes shifters) that if you clean the "bad taste" coating off of the battery you dont get those issues. On my MTN bike I got the error over and again wtih brand new batteries. Cleaned them off with some very nice stuff (brake parts cleaner) on a rag....no more issues. This was a thing on some of the cycling forums I guess.
Old Dec 24, 2024 | 09:48 AM
JettaRed's Avatar
Veteran: Army
Mountain Bike in Florida? Maybe ride across some golf courses.
Old Dec 24, 2024 | 11:44 AM
I thought the same thing...we have 110mi of continuous pretty cool trails.
Old Dec 26, 2024 | 08:41 AM
sab202's Avatar
C300 AMG Line W205
Made in Indonesia ... yay!! Sorry for the excitement 🤭
Old Dec 26, 2024 | 09:07 AM
I have had those exact same symptoms with brand new batteries that have that stupid foul tasting coating on them. Not sure how to remove them. I simply opt to buy batteries without the coating.
Old Dec 27, 2024 | 10:13 PM
cidtek's Avatar
C300 4Matic Tenorite Grey
I bought Panasonic batteries from Amazon and the issue went away.
Old Feb 10, 2025 | 05:08 PM
alvinC240's Avatar
I've similar fob battery issues with my E250 that has KeylessGo. Anyway, the battery that I use has 3.0V and it won't work. I finally use Sunbeams CR2032 and it has 3.2V and it works fine. My fob shall be CR2025, 3V that is slightly thinner. With the CR2032, it is slightly thicker with a small bulge on the cover. I've reviewed the W212 group chats about fob battery issues. They've the same problem.
Old Apr 13, 2025 | 07:20 PM
radio45's Avatar
C216_ CL550/C126_SEC
Same issue and fixed with Panasonic from Indonesia seemed to be the fix and or the Cr2032 worked on both CL550 and Gl450.
Old Apr 13, 2025 | 07:54 PM
W205C43PFL's Avatar
Most likely that bitter coating as mentioned.
Old Apr 15, 2025 | 08:12 AM
JettaRed's Avatar
Veteran: Army
Just hold your nose when swallowing.
Old Apr 15, 2025 | 08:16 AM
W205C43PFL's Avatar
Hopefully toddlers don't know this...
Old Apr 15, 2025 | 10:04 AM
I would be lying if I said I did not want to give one to the grandkid....just to see what happens (everything goes into his mouth)
Old Apr 15, 2025 | 11:28 AM
W205C43PFL's Avatar
Hopefully as expected and gets spit out.
Old Apr 15, 2025 | 12:17 PM
Bah, I have seen hundreds of things ingested, inserted, injected (with varying velocities) and on and on and on... if the worst thing a toddler gets in their tummy is a battery they should be set. Heck, the other day we had a lady show up because her toddler ate all the poo out of the litter box.....
Favorite to date? Guys who filled (his) large intestine all the way to his appendix with (liquid) plaster....they were trying to make a reverse mold cast.....(I guess the casts of the "front parts" went off with out a hitch).
