Best retrofit analogue audio input for W205 Audio20
Old Apr 29, 2024 | 04:56 AM
Merowinger's Avatar
W205 C180
Cool Best retrofit analogue audio input for W205 Audio20
Hi from Germany,
I am the owner of a W205 C180 sedan (built 01/2016) with an Audio20 infotainment system.
I recently "upgraded" to an Android Headunit (in Germany also called "Chinadisplay").
The Headunit has an analogue audio output. Unfortunately my W205 only has a digital audio input (USB port in the center armrest which is made for connecting an IPOD). That's why there is a small analogue->digital-converter in the center armrest which converts the signal and mimics an IPOD.
Obviously the sound quality suffers from the conversion from analogue to digital (the sound from the OEM-CD-player is much better than from the Headunit).
Unfortunately the Headunit blocks any Bluetooth connect except for AndroidAuto/GoogleCarplay.
Therefore I am looking for a good option to retrofit an analogue (3.5mm) audio input. I found this option on naviplus.com but it is rather expensive.
Can you recommend any other kits for retrofitting an an analogue audio input for my Audio 20.
Thank you for your help
Philipp
