I've been dealing with this for over a year now. The pressure sensor for refrigerant was replaced 1.5 years ago and the ac isn't working again. I saw a plug unconnected and apparently the tab is broken, when it was zip stripped on by a shol, the ac worked until I hit rough roads and it obviously popped off again. The zip strip was only on the shoulder.
My question is, is how easy or difficult is it to replace? And can it be reached from the top rather than taking the plastic off etc. A car without ac is just terrible..
it's a 2015 c300 4matic.
picture of connector?
Normally not hard to replace.
Take apart original by removing existing terminals and then inserting the into new connector.
hard part is figuring out how to remove terminals which depends on brand and type of connector.
Then worse case is cut wires and assy connector with new terminals.
