2021 C300 alignment
Old Jun 28, 2024 | 01:46 PM
tonynca's Avatar
2020 C300
2021 C300 alignment
We purchased the car almost 3 months ago. I noticed at times when going 70-80mph on the freeway the car would wander left and right which requires some steering input to keep the car straight. It doesn’t happen all the time, just certain pavement. So I went in for an alignment since the dealer didn’t perform one before selling us the car with brand new Continental runflats. The alignment guy came back and said it’s not off by much and he doesn’t think the toe was the issue with the wandering.
Here are the specs after an alignment: https://imgur.com/a/E3Rszgf
Why is there so much negative camber on the rear right wheel? With that much camber I’m gonna assume that the inner tire will get gobbled up after 10-15k miles. Why can’t Mercedes make it so we could adjust camber?!
Old Jun 30, 2024 | 11:06 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Plain and Simple - Todays models there is now only front and rear Toe directional adjustment !!
Front Camber and Caster along with rear Camber “has been deleted” (new car industry’s best kept secret).
It is all to do with ever increasing speed of new car assembly lines. STOPPING TO ADJUST CAMBER/CASTER SETTINGS IS NO LONGER AN OPTION !
Now one setting which is set at showroom height PUTTING ONUS BACK ON OWNERS TO FUND COSTLY, PREMATURE TIRE REPLACEMENT.
Brought about through day to day commuting encountering right hand passenger side excess edge wear - through high cambered roads or wheel squat through full passenger loads or lowering height / roll center for improved safety and handling response. Fitting wide profile tires - or just re instating “ongoing adjustment” capability not only for above but for resolving curb knock damage.
WE SAW THE NEED THEREFORE TO “FIX IT RIGHT THE 1ST TIME” - re instating once again full adjustment. K-MAC kits are also specially designed to “Bolt-On - No Special Tools” (or need for control arm removal to install).
SEE SPOILER RE ALL W205 MODELS C180-450 along with C43, 63/S AMG (kits mnf. to suit virtually every model Mercedes Benz Sedans, Coupes, Wagons, SUV’s and light commercials).
Spoiler
AUDI to VOLVO - Experience Of Resolving OEM Suspension Shortcomings (and costs) Since 1964 !
