COMAND system restarts after 10 secs and No sound
Hello, I have a 2016 C300 4 Matic with 70k KMs. The car was all running fine till yesterday when suddenly the screen/COMAND system started rebooting in cycle of ~10 secs. The system is a Non-Burmester basic system. Symptoms:
1. The system starts up normal in radio mode but no sound from speakers
2. The center console switches are working(except volume button) but the system force restart after appox 10 seconds
3. Steering mounted right side buttons are not working
4. There is a fan sound after a while (I believe this is normal sound system's cooling so fan is working)
5. There is large click sound when system restarts signaling like HDD might have crashed (if this system has any)
6. Tried disconnecting the battery for 1 min and well as checked the fuses but no joy
7. Engine stop / start is working fine so Aux Battery likely be fine
Please suggest next diagnostic steps as the back camera also turns off when the system restarts and wife is scared to drive without it :-(
Maybe playing stuff only dogs can hear?
Ya need to have it checked out because could be anything - CAN module going down... bad connection?
I know my gets funky when SIRIUS has those dayum FREE Views where everyone gets a few days of Sirius for free..
Mine crashes all the time and nav does not work - I do get sound though
Radio and Comand's NTG5 from w205 and w222 because of age, suffer from corrupted or defective NAND flash memory if the HDD is still alive. A proper diag and an electronic repair shop can solve this.
SPONSOR
WWW.BENZNINJA.COM
you need proper diagnostics (not some aftermarket toy)
SPONSOR
WWW.BENZNINJA.COM
Update: within the 10 sec time interval that I get, was able to connect my phone by selecting headset source as Bluetooth. It played the song for 4 secs and then displayed the message- Anti theft mode activated please contact MBenz dealer and restarted again. Any idea? I can confirm that nothing was added or removed from original configuration of the car.
looks like dead drive but can also be the rest of the hardware
best solution is to find another used unit from eBay not so expensive
get it programmed, then the antitheft code + a map as these are locked by vin
we can do all this
getting it repaired doesn't worth it as you might end up paying antitheft and map anyway
