W205 2.1L diesel bad interior heating
Hey,
I’m new here, and came with a little bit of a problem.
I noticed when the weather got colder that the cabin does not heat up very well.
After starting the car, when set to "HI", warmed air starts to blow quite quickly, but after the engine warms up to operating temp. that is lukewarm never warms up.
For example: I went to on a short 2 hour trip, maybe 6 degrees outside. I set it on "HI" and air direction to forward and legs. Blown air temp is barely warm (I tried to play with AUTO and SYNC). However, after trying to reduce the temp to 20, then again to "HI", I completely lost the warm air, it started to blow cold. Only the next day, after starting the car fresh in the morning, the "warm-ish" air began to blow again.
What could be the problem? The antifreeze level is fine, the engine warms up very quickly. Maybe someone had similar problems?
