W205 front parking light stuck on
Old Nov 11, 2024 | 11:41 AM
jtmack1's Avatar
I have a W205 2016 Mercedes C300 4MATIC that just the front drivers side parking light stays on all the time even when car is off. I found that there is constant 12 volts coming out of the front sam module to that light positive wire at all times. I am wondering if it could be a configuration issue or is the sam module bad? Can I get one used and get it programmed or do I have to get a new one and have the dealer set it up for the options on the car? Note I have unplugged the headlight and unplugged the headlight switch while troubleshooting and the wire for the light stays active. Any thoughts? Thanks Jason
Old Nov 11, 2024 | 03:36 PM
trigital's Avatar
W213 All-terrain
I would check the headlight ECU for water Ingres if the headlight is LED
Old Nov 11, 2024 | 05:20 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 forum...
