Electric Power Steering (Fault Codes)
Old Jan 24, 2025 | 08:27 PM
Cails's Avatar
Fault codes reading
B210D-00 The power supply is too low
B210F-00 Input circuit 30 has a malfunction
U0101-00 Communication with control unit transmission has a malfunction
Anyone got ideas about these codes showing up with intermittent steering malfunction issue.
Has anyone come across this and if so what is the solution ?
Old Jan 24, 2025 | 11:34 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
OPPORTUNITY TO FIX THIS: WELL OR WRONG...
Originally Posted by Cails
Fault codes reading
Seek timely professional help with this safety issue.
You electric steering rack is requesting attention.
The rack module is very sensitive to poor conditions.
Actually there may not be anything wrong with the rack itself but only poor environment conditions causing rack to act up. Namely
CAN-Bus signal
Floating GND
low power supply
Check chassis voltage while faults are active. Battery, Alternator or GND may have gone marginal.
Old Jan 25, 2025 | 04:53 AM
Cails's Avatar
Thanks could something such as the ghost immobiliser causing this to happen?
Old Jan 25, 2025 | 05:14 AM
electric steering use no ESL immobilizer.
Old Jan 25, 2025 | 07:26 AM
trigital's Avatar
W213 All-terrain
More likely some water over the connectors,
Old Jan 25, 2025 | 09:02 AM
Cails's Avatar
Thank You
Power steering malfunction light occasionally also popping up on the dash
Old Jan 25, 2025 | 03:45 PM
Thank You
take your car to your independent MB specialist whom you trust will not jump at replacing your $8000 steering rack for a basic GND post oxidation issue.
Your faults show a marginal PWR/GND connection.
Have you driven in heavy rain or standing water ??
