2015 C Class windscreen washer pump issue
Old Mar 24, 2025 | 03:36 PM
DanC220d's Avatar
C220d W205
Hi,
My windscreen washer isn’t operating when pressing the button on the stalk but the wipers are wiping when pressed. I thought the pump had failed so replaced it and still the same issue. I tested the original pump off the car and that’s fine so put that back in the car but still no power to it when pressing the button. I plugged in a diagnostic tool and found the module to test and it works fine, just not on the button on the stalk. Could this be the stalk it’s self that needs replacing? Although when pressed the wipers operate so I thought it would either all work or nothing. Any suggestions? Thanks, Dan.
2015 c220d bluetec, Sport, Estate, UK.
Old May 6, 2025 | 02:56 PM
AeroV's Avatar
2017 W205
Hello,
I have the same problem, did you figure it out?
Old May 7, 2025 | 01:37 PM
DanC220d's Avatar
C220d W205
Hi,
yes the button on the end of the stalk was stuck. I just banged on and it broke lose and started working again.
Old May 7, 2025 | 01:47 PM
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
It is relatively cheap to replace the windscreen washer pump, I'm showing about $20 for the part and less than an hour labor.
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
Old May 8, 2025 | 12:53 PM
AeroV's Avatar
2017 W205
Indeed, mine was stuck. Wacked it and voila!
