Reverse Camera (Black screen issue)
Old Apr 16, 2025 | 07:38 PM
ashd's Avatar
2019 Mercedes Benz W205 C63s Facelift
Vehicle: 2019 W205 C63s Facelift
Hi all,
I’m hoping I get some assistance in relation to this issue. Everytime I put my vehicle in reverse, the reverse camera works for 2 seconds roughly and then shows a black screen. The rear camera flap is in open position, I have tried lubricating it with WD40 and also cleaned it without any success.
I have attached a url of a short video for reference, your assistance will be much appreciated.
https://www.dropbox.com/scl/fi/zvlhx...=n48sgytm&dl=0
Old Apr 16, 2025 | 09:12 PM
W205C43PFL's Avatar
Hi all,
Perhaps plug a scanner in the vehicle and see if there is a stored code, thought it was a calibration issue but doesn't seem to be so. I did notice the camera is clearly blurry so not sure if it is a hardware issue, hopefully not.
Old Apr 16, 2025 | 09:14 PM
W205C43PFL's Avatar
Could it be the wiring loom mentioned here? https://mbworld.org/forums/c-class-w...d-working.html
https://mbworld.org/forums/glc-class...t-working.html
Old Apr 16, 2025 | 09:16 PM
ashd's Avatar
There's nothing on the scanner and the camera is just dirty, just needs a clean.
Old Apr 16, 2025 | 09:30 PM
ashd's Avatar
Thank you for your reply. I don't think the last two forums are related the camera is operational. It may be a loose wiring loom?
Old Apr 16, 2025 | 09:31 PM
ashd's Avatar
Thank you for your reply. There's nothing on the scanner and the camera is dirty, just needs a clean.
Old Apr 17, 2025 | 07:53 AM
W205C43PFL's Avatar
You're welcome, check the wiring loom as mentioned.
