I need help please
Old Oct 1, 2025 | 09:34 PM
Luissilva95's Avatar
2017 C300 Base
I need help please
I have a 2017 w205 base at 130k and i have this squeaking wont go away i changed the belt,tensioner and idler but it still stays my dealer had their mechanic check it and they say nothings wrong my dad thinks it may be the water pump but the car isnt overheating and doesnt leak it doesnt even leak water when the ac runs the squeaking is bad when im in drive or reverse or the ac is up higher than 5 if anyone who is a tech or has had the same experience could give me some advice i would really appreciate because im not sure if i should just buy the ac compressor or a water pump i have a video but i cannot post it
Old Oct 1, 2025 | 11:02 PM
G63GT63SE's Avatar
2025 AMG G 63 SUV /// 2025 AMG GT 63 S E Performance 4 Door Coupé
Have you checked to see if it’s the power steering? Dry steer lock to lock and listen for any changes in the noise then report back to us.
Cheers and happy hunting
P.S. A sound clip would be helpful. A video taken under the hood would be even more helpful.
Old Oct 1, 2025 | 11:24 PM
2017 C300 Base
Here under the hood
Old Oct 1, 2025 | 11:26 PM
2017 C300 Base
Here is when i change gears and when i turn off ac it stops
Old Oct 2, 2025 | 05:59 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
replacing tensioner and idlers was wise!
Compare original belt numbers with new one: a lot of corrupted belt cross-reference has spread all around starting with the EPC source.
The original belt reference is what your engine configuration needs - Ignore databases.
