Reverse Camera Opens and Closes
Old Nov 15, 2025 | 11:53 AM
mnc365's Avatar
Angry Reverse Camera Opens and Closes
Hi all, I recently bought a 2014 C200 (W205) and was thinking to myself "best car I've owned". Then the reverse camera stopped working
When I put it in reverse, the camera pops out and then retracts instantly, so there is power. There is no change in the infotainment screen when put in reverse but the white reverse lights do come on and the side mirror does dip. I checked the fuse in the boot for the camera which isn't blown and the wiring to the camera has no frays when I opened up the lining to check. If it helps, I did wash my car and it stopped working since then.
What could be causing it? Any help would be appreciated.
Old Nov 18, 2025 | 04:32 AM
C3-5hitty's Avatar
2018 C300 (w205, m274, 725) and 1995 Ford Bronco (5.8 Windsor)
Lightbulb
Former Benz tech here. First question: do you have a license plate frame? Theres very little clearance between the license plate frame placement and the back up camera. It could also be a calibration issue and you wont always get a message on the dash for the camera. Let me know so I can better help.
Last edited by C3-5hitty; Nov 18, 2025 at 04:33 AM. Reason: forgot title. dont know how to fix that lol
Old Nov 18, 2025 | 10:41 AM
Andy74's Avatar
W205 2015
How about you dry it with a hot air blower since it started to do this after you washed the car but it shouldn't there is something wrong why water would go in there
Old Nov 18, 2025 | 01:32 PM
mnc365's Avatar
Thanks for the advice. I don't have a frame. I removed the plate itself and put it in reverse but still no luck. Pops out and straight back in again, with no change in the display screen.
