2015 C400 vibration a 2200 RPMS
Old Mar 7, 2026 | 11:53 AM
Richtotherob's Avatar
2015 C400
I have a 2015 C400 with 127k miles. I had to replace a broken flex pipe that would rattle badly at 2200-3500 rpms. After the flex pipe was replaced I now have a vibration at the same rpm range. It is felt in the gas pedal and steering wheel and is audible. It does it in park and in drive. Any ideas what could cause this?
Old Mar 7, 2026 | 01:59 PM
Andy74's Avatar
W205 2015
Get someone to press the fuel pedal to reach the 3000 rpm while you go underneath the engine bay see if there something visible causing the vibration
Old Mar 7, 2026 | 02:03 PM
Andy74's Avatar
W205 2015
Check this thread as well it looks like he has the same issue:
https://mbworld.org/forums/c-class-w...under-car.html
Old Mar 8, 2026 | 12:08 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
shaky engine matter
Your engine is currently sitting on its muffler line.
Find a MB specialist to replace your 2x engine + 1x tranny mounts.
About being proactive...
> Inspect the plastic coolant elbow hose at driver side firewall. It's likely leaking now.
> Shaking... when were your spark plugs last replaced??
> CPS protective pigtails installed?
