2020 C-300 A/C Not Cooling
Old Apr 26, 2026 | 04:58 PM
zpcsc's Avatar
c-300
My A/C unit is not cooling properly, it blows air but not cold like it use to, it's Intermittently. We just changed the cabin air filter but it didn't help. I noticed this a few months ago but now it's happening more often.
Any suggestions?
I appreciate all your input.
Thank you.
Old Apr 26, 2026 | 06:16 PM
streborx's Avatar
Top Answer: 1
G550
Several items can cause inadequate cooling including the loss of refrigerant, a malfunctioning compressor, or a defective evaporator. These aren't easy DIY diagnostics, but you can check fuses and make sure you don't also have the heat turned up (hey, it happens). You might have to visit a dealer or A/C specialist shop.
Old Apr 27, 2026 | 05:20 PM
TimC300's Avatar
I hardly ever turn the ac on in my W204 and prefer driving with the windows and sunroof open.
Last summer I decided to turn it on just to check if its working and it was blowing hot air. Long story short I added about 1/2 can of refrigerant in and back to cold air. I made sure to use straight refrigerant with no stop leak stuff that can clog up the sytem.
I used my Foxwell OBD scanner to see refrigerant pressure, see the evaporator temps and function test the ac compressor as well as check for any fault codes. Seeing the evaporator temp was helpful to determine if it was an ac issue or vent issue like blend doors not functioning.
With the scanner I saw the ac compressor was turning on and functioning but the refrigerant pressure remained low and the evaporator temp wasnt getting colder. Bought an inexpensive refrigerant install hose with gauge and saw when the ac was turned on the low side refrigerant pressure dropped.
I wrote a thread on what I did but cant seem to find it.
When i was done the low side pressure was around 36psi on the gauge and was seeing around 10-11 bar on the scanner depending on fan speed. Evaporators temps dropped indicating it was colder.
Old Apr 28, 2026 | 02:20 PM
TimC300's Avatar
I was able to find the thread i made when trying to figure out why my ac was blowing hot air.
Can be viewed here: https://mbworld.org/forums/mercedes-...ctions-do.html
Old Apr 30, 2026 | 03:51 PM
zpcsc's Avatar
c-300
Thank you, I did take it to the mechanic. He added refrigerant and used a syringe type injector which if it's a small leak it should be able to seal it. If it stops cooling as it should not to take long to take it in. So hopefully all will be good.
Old May 1, 2026 | 09:41 AM
streborx's Avatar
Top Answer: 1
G550
Glad you got it fixed -- hopefully the leak is remedied. TimC300 provides helpful DIY info above. As much as a committed DIY'er I am myself, I draw one boundary at A/C systems where I lack the tools and experience. There are several different refrigerants, and I'm certain I'd mix them up and create a real mess. I hate having to take my car to a mechanic, but there are times it makes sense.
