Engine ground strap
Old Jun 18, 2026 | 04:21 PM
Mercmiester's Avatar
C300 15
Lets find out...
LOGICAL:
You can use your favorite MB scanner to read module status
ELECTRICAL:
You can trace wiring with schematic to measure vitals: voltage and working bus
MISC:
What else are you considering?
You've got to start somewhere:
find leads from the essentials: PWR + GND + DTA
nothing until the oil sensor.is fixed. Its shorting out while driving so, warning lightq on then off.
Old Jun 18, 2026 | 05:12 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
shorts... not casual
Originally Posted by Mercmiester
nothing until the oil sensor is fixed.
Its shorting out while driving so, warning lights on then off.
If bad oil sensor is really shorting out actively, it may cause more damage to ECU circuit or blow a fuse protection.
Besides while connected, leaky sensor provides oil spread throughout the engine harness by capilllarity.
Old Jun 18, 2026 | 05:27 PM
C300 15
its disconnected
Old Jun 18, 2026 | 06:05 PM
its disconnected
Ok, that's best for now
"An ounce of prevention is worth a Pound of cure".
Oil in harness is hardly ever easy to deal with.
Old Yesterday | 03:08 PM
C300 15
another discovery, rhe fuse box gets 12.3 v from battery but the circuit 87 relay is only getting 11.79. Whats the problem here? Do I need a new fusebox
Old Yesterday | 04:24 PM
another discovery,
the fuse box gets 12.3V from battery
but the circuit 87 relay is only getting 11.8V.
Good catch
You're seeing a 0.5Volt drop!
This voltage drop is not directly bad for every circuits...
This won't stop your head unit from working.
There are a lot of distinct physical connections made between the 12.3 and 11.8 - Each connection is an opportunity for voltage drop and maintenance work.
I've been hunting voltage drops for years... the long story short here is you can focus on the SAM Relays cubes and the prefuse box internal connections. They are responsible for dropping voltages under load!
Furthermore...
-- Charge up main battery full (CTEK!) to have a more stable voltage that does not change under most loads.
-- Experiment disabling variable "ALT Opportunistic charging"... "Alt-LIN:OFF" to get a stable chassis power for ignition and injectors. This positively affects the engine learned maps.
Old Yesterday | 04:42 PM
  #32
C300 15
Good catch
Furthermore...
im more.confused. if i change rhe oil level sensor, does that mean this would largely be solved?
Old Yesterday | 06:31 PM
  #33
C300 15
Good catch
Furthermore...
I also discovered the car doesnt want to let the gear level work until I turn the wheel a bit. Wtf.
Old Yesterday | 08:16 PM
  #34
you tested the sensor to find it was shorting out... that's a good enough reason to replace it.
These oil sensors are not too reliable with evidence of oil leaking through... Getting a new sensor was a good call.
Old Yesterday | 08:21 PM
  #35
See all the things that can be found with good testing....
The Steering Column has a module that benefits properly soldered connections. Direct your scanner to read SCM data... while gently turning side to side...
Neaby front footwells have shared GND posts many VIP Modules get referenced to. These GND deserved to be cleaned of the factory paint they got.
