AC Temp During Auto Start/Stop
I just purchased my 2022 C300 about a month ago here is the US & I wanted to see if others are getting the following behavior with theirs:
Whenever the engine is off due to the auto start/stop system, the air from the AC vents gets warm. As soon as the engine kicks back on, the air cools back down again. I also notice that the engine restarts after maybe just a minute or so. It doesn’t seem like it can remain off for very long. This is very different from my 2021 GLE 53 where even after the engine is off for several minutes at a red light for example, the air remains nice and cold.
I am curious if this is normal in the C300 and if so, does anyone know what is behind the difference in behavior? I could be wrong, but my understanding is that in both the C300 and the GLE 53, the AC compressors are electrically driven.
Thanks in advance!
Thanks in advance!
- the voltage of the battery falls below a certain amount
- or the temperature sensed inside the cabin falls below a temperature spread from the user setting.
Difference in temperatures perceived by the user in the cabin changes by size of the air conditioner installed on each vehicle when the motor is not running. (A larger SUV will have larger radiators though the air flow will stay cooler for longer time)
Electric vehicles run air conditioning units because the size of the batteries installed are nothing like the one we have in the C class.
I do not base my statements based on technical knowledge of this particular vehicle but on previous owned ones and other systems I’m familiar with.
Once, I noticed the airflow wasn't cold enough after setting it on LOW with max fan. Just restarted the engine and made it work normal. Only happened once though.
hi 818benz
I live in the valley too here in Los Angeles. I do notice the AC isn’t as cold when I have the start stop engaged and does get colder when I turn it off. It did this on my 2020 C300 too.
