C-Class (W206) 2021 to
W206 Sound System Help
Old May 16, 2024 | 05:12 PM
MJBURTON23's Avatar
Mercedes C300 Coupe
Hi,
I have placed a reserve on a W206 C300 Premium Plus. Car was built in 2022 and so unfortunately due to chip shortages is missing the Burmester sound system. Is there any way of telling from the factory spec sheet what audio system is fitted in the car - I have looked through and nothing is noted.
Any assistance would be a great help so I can decide whether to go ahead with the purchase.
Spec sheet attached - I’m going to view the car on Saturday and the dealership aren’t 100% sure what system is fitted.
Last edited by MJBURTON23; May 16, 2024 at 05:26 PM. Reason: Missed vehicle description out
Old May 18, 2024 | 09:35 AM
giovane's Avatar
2023 C Class
If you are located in US, there are only two audio systems available. Base and burmester. It’s easy to spot the difference because cars equipped with burmester have the metal speaker covers.
European spec cars have also an Advanced audio system that sits between the base and burmester.
Old May 18, 2024 | 11:43 AM
MJBURTON23's Avatar
Mercedes C300 Coupe
Thanks mate. I’m located in the UK so adds a layer of uncertainty since there are 3 options here: the base system, the midline system and the Burmester.
It’s clear the car doesn’t have the Burmester from images (noting the silver speaker covers) but no mention on the spec sheet of anything related to the sound system.
Old May 18, 2024 | 12:20 PM
giovane's Avatar
2023 C Class
Most likely you have the base sound system. The advanced system has code 853 and it’s missing from your option list.
Read this thread for more information
https://mbworld.org/forums/c-class-w...ml#post8786004
Old May 18, 2024 | 06:09 PM
Povitica3's Avatar
2022 C300 AMG-Line; 2020 E450; 2013 SLK350; 2023 EQS580
No silver covered speakers means no Burmeister. And the spec sheet will specifically call out a Premium Sound system indicating a Burmeister installed. So if none of these two are found, easy call - no Burmeister
Old May 19, 2024 | 03:25 AM
MJBURTON23's Avatar
Mercedes C300 Coupe
Thanks all.
This thread can be closed I’ve decided to order a brand new car so that all of the relevant options are included in the build.
