First off, just to clarify, what year is your C300? You are posting in the W206 forum, so I'm going with that for now. How to set your reference tire pressure should be covered in your owner's manual. Whenever you change your tire pressure or are not sure what pressures were previously stored, make sure you check the pressures when the tires are cold, then go to Service | Tires and set the reference tire pressure there. It's straight forward. Not sure what prompt you are getting specifically, but there is no predefined set pressure for the tires. You store the preferred pressure yourself based on what you are setting them to. Take a look at the inside of your fuel door and you'll see that there are different recommended tire pressures for different load, driving and tire situations. Since there isn't one recommended pressure for all situations, you inflate the tires to the one that matches your situation and then store them.
As for navigation, if the car wasn't optioned with navigation from the factory, you will still have the button, but navigation itself isn't installed. With the W206 and other newer vehicles you can purchase navigation through the Mercedes me connect Store after the fact.
