C-Class (W206) 2021 to
Gearbox Issue?
Old Sep 29, 2024 | 11:46 AM
Tokra's Avatar
MB C300e S206
Gearbox Issue?
Hi,
I have a 2023 C300e PHEV Estate. I noticed the phenomenon on the car, is that in 1st gear, the gearbox makes a low, but audible uprising sound in proportion to the revs (as I put the pedal and incrase the speed). Like when a spaceship takes off, but very quietly. In higher gears it is no longer audible. Is this normal or a warranty problem? The reason I ask here is that the dealer will probably tell me straight away that it is normal. Even if it is not normal.
Anyway, the shifts are smooth, I don't feel any other problems (except that sometimes you can feel the shifts, especially at low speed, but supposedly this is normal with the 9G tronic)
Old Sep 29, 2024 | 12:56 PM
ChrisJ214's Avatar
2025 C300 4Matic Blk/Blk
While I don't have a hybrid Mercedes, my wife has a hybrid Hyundai Tucson. I know that when you first start out, the vehicle has to make a sound while in electric mode to alert those around it that it is moving. Once the combustion engine starts up, it will quit. Not sure if that is what it could be, but I know that is a requirement for that sound. And a spaceship sound is what most people describe it as.
Old Sep 29, 2024 | 01:22 PM
Tokra's Avatar
MB C300e S206
Thank you for your reply!
I am aware of this, but unfortunately it is not the case for me. The sound curves upwards when shifting up, then immediately afterwards drops downwards. The sound is definitely like a gear "slipping" in the gearbox.
The pedestrian protection sound of EVs is not like that (my wife has an Ioniq 5, and it has a distinctive continuous sound).
Old Sep 29, 2024 | 01:31 PM
ChrisJ214's Avatar
Well, I thought I would share it in case you were not aware. Since you are and can say it is different, the only thing I could recommend is to let the dealer look at it.
Old Sep 29, 2024 | 01:42 PM
Tokra's Avatar
MB C300e S206
Yes, it will be the best! Just thought it might be like the "jerk shift" in all mercedes. Maybe if more people hear it, I won't worry.
Old Oct 11, 2024 | 01:54 AM
chenjie's Avatar
Hi,
I have the same model, yes, sounds like a spaceship take off, only audible in lower gears in EL.
Old Oct 11, 2024 | 02:14 AM
superswiss's Avatar
2019 C63CS
That sounds like what you are hearing is the electric motor between the engine and transmission that assist when you are starting off the line. That would be normal. Once you are moving and the engine is in the powerband it no longer assists. It also assists during shifts to do torque fill or at lower rpm before the turbo spools up, but you probably won't hear it anymore over the road noise above a certain speed.
Old Nov 1, 2024 | 11:23 PM
Tokra's Avatar
MB C300e S206
Thank you everyone!
I hope this is indeed the case!
I noticed something else...There is also a lag when accelerating in electric mode. If I suddenly floor it.
Old Nov 2, 2024 | 09:02 AM
Murton's Avatar
W206 C300e AMG Line Premium Plus with driver assistance package
I believe the oil pumps on these engines are electric. I suspect if you suddenly floor it and the engine hasn’t recently run then it will start circulating oil before suddenly starting the engine at 4000+rpm in order to reduce engine wear.
