C-Class (W206) 2021 to
Retrofiting ventilated seats - dealership
Old Nov 7, 2024 | 03:19 PM
olej1337's Avatar
C300 4M 2024
Hello,
I was wondering if anyone here did retrofit ventilated seats to their car. Unfortunately I didn't spec mine with those which I regret.
I saw some aftermarket (and supposedly OEM) kits on eBay, but is it possible to fit those in a dealership or without voiding warranty?
I am from Europe if that's important.
Maybe someone has already done it?
Thanks for any info
Old May 27, 2025 | 10:50 AM
EleBest's Avatar
SPONSOR
E200 2010, G63 2018, E53s 2019, EQS53 Touring 2021, S500 2022, A200 2023
Originally Posted by olej1337
Hello,
Thanks for any info
Retrofit this option, by original way, you need get leather and Cushion changed and door switch cluster changed, in order to get 100% same result like Original.
In order save money: you need sacrifice the appearing first: you can punch holes manually on your seat leather, which might not look so perfectly. But it works.
And you need sacrifice the airflow perfection: buy using customised foam hole driller and use sticker to controller the airflow.
and you need sacrifice the comfort of your seat cushion as you have to cut two big hole to let the fan to stay under the foam and behind the foam.
The final result is fully controlled by your own hand.
we suggest you buy one set to have a try. See if works nicely.
original leather with ventilation seat is like this one:
