Automatically selecting charge mode
Sometimes when i arrive at home or work i forget to press the little "Select home/work charging mode" (or whatever it says in english) on the screen and it results in my car not charging at all, wich is a bummer, especially at work when the max charge speed is 1,7kwh, so even if i remember to check the app and activate charging later in the day there isnt enough time to fully charge.
technically a 11kw charger is classed as a fast charger so it is technically correct that the car shouldn’t charge unless fast charging is enabled. That said however it is a poor option to have fast charging disabled by default. It would be much more logical to have it being ‘dc fast charging’ being enabled or not so 11kw is considered the same as 7kw charging.
