Installing additional USB power charger cable
I was thinking to install a fuse tap on the right side of the vehicle and pull the cable to the glovebox. I found this website with fuse box locations and schemas:
https://www.startmycar.com/mercedes-...anchorfusebox2
but before "venturing" further I would like to know if anyone here already did something like this and what fuses did you choose?
Thanks.
Thanks.
There is also with a higher wattage and faster charging.
https://www.proclipusa.com/products/...er-single-port
Also, if you do want it to be inside of the glovebox, ProClip also sells this. It's an additional 12V socket that you can wire to your fuse box, and then you can insert a 12V socket USB-C charger in it. Remember, just getting power into the glovebox doesn't do anything. You need the USB-PD charging circuits.
https://www.proclipusa.com/products/...-power-adapter
