C-Class (W206) 2021 to
How charging W206 48v battery?
Old Feb 19, 2026 | 03:58 AM
Setareh's Avatar
How charging W206/ C200/ 48v battery? it does not start, do you have any WIS document relating to remove install and charging 48v battery?
Old Feb 19, 2026 | 09:09 PM
818benz's Avatar
2025 C300
I believe the 12v battery used to feed the 48v battery. When I leave a battery charger plugged in over night at the hood, I access workshop menu and see the 48v battery goes up in charge maxing out at around 75%.
Old Feb 21, 2026 | 04:12 PM
UrBusted's Avatar
Porsche Taycan, Range Rover AB, Range Rover SVR, S Class, Mclaren 570s, Urus Hybrid (soon), M3, RS6
Mind sharing what your issue is? If you don't even have Xentry/WIS I doubt you can remove the 48v battery. You have to initiate bleeding the cooling system, follow some procedures and deal with the BMS issues; that's forgetting the specific 48v charger required which only hybrid battery shops really have. Is the issue that the car's been in an accident?
Old Feb 22, 2026 | 05:27 AM
Setareh's Avatar
There is no accident. if you have WIS, you can print the related documents to Pdf and if it's possible please add to this chat.
Old Feb 22, 2026 | 01:01 PM
olddude's Avatar
C300
You mean the little Hybrid part for extra horsepower? My C300 has a blue "charging" indicator on my display. Is yours not working?
