C-Class (W206) 2021 to
My turbo got red hot after two pulls is that normal?
Old Feb 21, 2026 | 09:40 PM
Thekiller114's Avatar
c 300 w206
Old Feb 21, 2026 | 09:54 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
My best guess is that’s not normal.
Old Feb 21, 2026 | 10:00 PM
c 300 w206
Idk oil temps seemed normal 100-111 Celsius
Old Feb 22, 2026 | 01:41 AM
superswiss's Avatar
2019 C63CS
Normal. Exhaust gases can reach 1,700F or higher under heavy load, which causes the turbine side to glow red.
Old Feb 22, 2026 | 10:56 AM
c 300 w206
I know that this happens to turbos but that quickly seems weird, I was thinking to add VP cool down to my cooling system to help cool things down but I couldn't find a Min or a Max on my coolant reservoir.
Old Feb 23, 2026 | 04:51 AM
ygmn's Avatar
2015 E400 Sedan
Normal when High HP demand from engine like a dyno pull where you max out engine demand to see what she's got.
That is why when you about to park car for long periods of time after drive:
Drive smooth & slowly to keep turbo from spooling up and getting hot.
Old Feb 23, 2026 | 07:41 AM
W205C43PFL's Avatar
Reminds me of turbo timer days for this reason, turbos needs to be cooled down after a spirited drive.
Old Feb 23, 2026 | 07:55 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Yep - my fave was the Blitz SBC-iD with a GReady turbo timer......not too infrequently I will let the car run in the garage for a few minutes to cool my turbos (in three of my cars). The big one has a MASSIVE turbo and I have never really considered its temps. That said, there is a water pump in our GLS and my E63 that continue to move water after the engine is shut down. I have to assume the C has the same thing?????
Old Feb 25, 2026 | 07:15 AM
W205C43PFL's Avatar
Good question, will need someone to look at the engine technical docs for more information.
Old Feb 25, 2026 | 07:48 AM
Same part number as the E63 and GLS
Old Feb 25, 2026 | 08:03 AM
C280 Sport's Avatar
MB’s of all kinds.
Normal. Especially since the turbos are providing you with that high amount of power needed to conduct those hard pulls. After the pulls are done pull off let the turbos cool down a bit and park it.
