Battery for C 300 W 206
I am getting low battery message when I keep the car parked for longtime without using it, my C300 is 2023 manufactured, I believe it is time to change the Battery , my questions :
1- which brand and model is recommended?
2- will it affect the me connect MBUX while changing it, do I need to ask the dealer to reconnect me? or it is hard swapped?
You may not need to change the battery if it recharges after driving. I received low battery several times after going on vacation but the battery health/condition in MM app still shows good.
For the 48v battery I would only use an OEM battery. I also suggest an OEM 12v battery, however VARTA makes these batteries and you may be able to find a suitable non-MB branded varta battery.
Unfortunately, the batteries have to be coded into the car using a computer when replaced so that they're correctly recognized.
As for the coding, some obd scanners such as launch creader elite benz V2.0 can do it unless you have XENTRY then even better.
CTEK - 40-206 MXS 5.0 Fully Automatic 4.3 amp Battery Charger and Maintainer 12V.
Been using it since last September with no problems.
