C218 CLS63, 2011 - 2019
Installed clear front side markers on 12 CLS63.
Old Nov 26, 2011 | 07:08 PM
ajag's Avatar
12 CLS63
Thanks to FlyC63 for trying the S63 clears and verifying they fit perfectly. I got them off ebay w/ the stealth bulbs from seller http://myworld.ebay.com/nikki-7002/&...84.m1439.l2754
Slightly annoying install until I figured out you can sneak a hand behind the wheel well liner w/ the wheels turned full opposite lock.
Attached Thumbnails Installed clear front side markers on 12 CLS63.-photo-2-.jpg   Installed clear front side markers on 12 CLS63.-photo-1-.jpg
Old Nov 26, 2011 | 09:50 PM
turbotom1's Avatar
SL63
Thanks for the tip, been looking around and never found these.
Old Nov 27, 2011 | 03:20 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Nice. They look good.
Old Nov 27, 2011 | 09:48 AM
Gathofbaal2010's Avatar
2012 CLS 63
Looks very nice! On my C63 I tried to keep everything stock so I covered the orange reflector with a color matched vinyl wrap--if I get a ticket, easy to remove. I however really like the clear markers as it appears to pass the police sniff test and looks very sharp with the stealth bulbs.
Is this the part you ordered from ebay '2010-11 S CLASS W221 S550 SIDE MARKER PARK LIGHTS CLEAR'--how much did you pay if you wouldn't mind posting/PMing?
If you wouldn't mind a quick go-by as well that would be great! I removed my C63 side markers without much ado-- all accessed from the engine compartment... accessing from the wheel well is not an approach I'm familiar with.
Old Nov 27, 2011 | 09:49 AM
2012 CLS 63
It may not be clear from the above post-- I don't want to install the s clear markers on my c63--it'll be a 2012 CLS63.....
Old Nov 27, 2011 | 09:58 AM
ajag's Avatar
12 CLS63
Yep, that's the part, I got it for the buy it now 52.95 price.
I had a C63 that I did clears too as well, it was easier since as you said it's accessed through the engine bay.
I used the Macarbon plastic flat tool (can use any flat plastic piece to wedge in between) to pop out the OEM corners from the upper back corner and swapped out the bulbs, then I stuck my hand through the hole to push the fabric wheel well liner out so I could stick my other hand through the wheel well to hold the inner black plastic piece in place while I snapped the new clear corner into it. The S550/63 clears are a perfect fit.
I just swapped out to clear corner LEDs on my R8 which was a lot harder as I had to jack the car and take off wheels, and undo torx bolts to get around the plastic liner, the benz is much easier as it's more flexible liner (and there aren't bolts you can unscrew anyhow).
Old Nov 27, 2011 | 12:03 PM
Vic55's Avatar
Administrator
Looks good on the white. I personally like the paint matched ones better if its not on a white car though.
I still hate the orange lighting at night so I tucked the bulbs away in the bumper. I get no orange during the day or night- no different than the euro models.
Old Nov 28, 2011 | 12:12 AM
FlyC63's Avatar
12 E63 matte white
Enjoy..glad you liked it! IMO it only looks good on light color cars.
Old Nov 28, 2011 | 04:22 PM
Centurion's Avatar
a car that gets very poor gas mileage.
Agreed.
I had mentioned this in another thread as well.
Specificlly, white colored cars.
Every other color will look better color matched.
Great job to OP. Looks good.
Old Nov 28, 2011 | 05:18 PM
derrick_lui's Avatar
My ex-cars: 03 E55,04 C32, 05 C55 ,03 E320
Looks great!
Old Nov 29, 2011 | 10:33 AM
ajag's Avatar
12 CLS63
Thanks for comments guys. I agree it may not work on a darker color. Anyway, nice to pop the modding cherry on this car w/ a DIY cheap easy install. Next week she goes in for a bit more work.
Old Feb 10, 2012 | 10:28 PM
XRAYAMG's Avatar
14 SLS Black Series, 09 SL65 AMG Black Series, 15 G63 AMG, 15 Ferrari Speciale, 16 GTR Nismo
how did you get your hands behind the wheel liner? did you take out the rivets?
i'm having a difficult time removing the side markers.
Old Feb 11, 2012 | 09:10 PM
ajag's Avatar
12 CLS63
No, I popped out the side marker first and stuck my hand through the hole to push the liner out enough to stick my other hand through the wheel well behind it.
Btw, are you a radiologist too?
Old Feb 12, 2012 | 12:21 AM
vdubpower's Avatar
i drive them all, fast and hard
need to find these for my E
Old Feb 12, 2012 | 08:53 PM
XRAYAMG's Avatar
yes. ir.
i was able to get a credit card behind the side marker, but couldn't pop it out. any tips?
Old Mar 7, 2012 | 02:34 AM
freefall's Avatar
2012 C63 Purpose built race car, 2015 CLS 63 S, 2016 GLA45, 2017 GTS
yes. ir.
Use a flathead and a towel (to protect the paint) to lift out the liner enough to get your hand in. Works like a charm.
Old Mar 7, 2012 | 07:49 AM
hyperion667's Avatar
2012 CLS63
yeah you do,
Old Mar 7, 2012 | 01:43 PM
vdubpower's Avatar
is the removal process the same on the E, prying it out
hyp did u get smoked or clears for your E's
Old Aug 5, 2012 | 12:56 PM
Rock's Avatar
Administrator
Drives Slowly
I also purchased the clear side markers from Ebay and they are a perfect fit. I just installed them on my car and have a few things I would like to add.
First, The easiest way to remove the stock side markers is to sit in front of one, then slip your hand behind the wheel liner (it is easy to displace). Next, snake your hand behind the marker and feel for a projection. This is a retaining clip.....just push it outward (towards your face) and the side marker will release from the assembly .........no tools are needed. From there, just twist the bulb to remove it from the stock amber marker.
Regarding the bulbs that are provided with the clear markers: They are amber in color and only come on when the headlights are on. They do no light when the daylight running lights are on. I actually like the look of the clear lenses and will not paint them. I am also going to go with a white LED light to match the rest of the lighting. I picked up some 194 LED bulbs at autozone. Do not make that mistake because you will get a fault code. After a little research, I think I found the answer.........these fault free LEDs. The should look great.
http://www.ebay.com/itm/200801865333...ht_1575wt_1398
Do not use the above light. Too bright for a side marker.
Old Aug 5, 2012 | 03:29 PM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
AZNOptics has them. Error free 100%. Best part is if they burn out, just send him a pic and he'll replace them at no charge. Always had good communication/business with him thus far.
Old Jun 24, 2013 | 11:11 AM
m_h_sagaf's Avatar
Cls63 2013
I need this part cls w218 side white light for both pices.
Old Apr 11, 2017 | 01:23 AM
6speeddave's Avatar
MB
i have a pair of the clear DEPO bumper lights if anyone is interested for W218 AMG & W221 AMG
Old Nov 17, 2017 | 07:42 PM
delirium's Avatar
C350
I bought a set of depo smoke/clear LED sidemarkers with yellow LED lights and installed them today. Fit well and the LED's look great when off and when on.
