C218 CLS63, 2011 - 2019
2012 CLS63 - Stop/ Start
Old Feb 18, 2012 | 09:32 AM
Saeedg48's Avatar
2009 CLS63 AMG
Lightbulb 2012 CLS63 - Stop/ Start
is there anyway you can set the car to default with start/ stop off.
i really hate this feature.
Old Feb 18, 2012 | 12:12 PM
freefall's Avatar
2012 C63 Purpose built race car, 2015 CLS 63 S, 2016 GLA45, 2017 GTS
My kid left one of the doors open and drained my battery. I jump it and hit the road. First red light and the eco turns my car off and won't start again!!! As you know its in the shop and I told them to find a way to disable it. Its terrible and a joke for people who are spending 100K on a car that gets 12 MPG. I'll let you know...
Old Feb 18, 2012 | 01:29 PM
hyperion667's Avatar
2012 CLS63
you mean you have to disengage it every time???
Old Feb 18, 2012 | 01:31 PM
Saeedg48's Avatar
2009 CLS63 AMG
yup
Old Feb 18, 2012 | 02:11 PM
Vic55's Avatar
Administrator
A simple programming of the AMG button is all it takes. Yes you have to push the button and for some it seems unfathomable that this should occur but like I said- push the button and ECO is gone.
My 997TT requires two pushes (sport mode and spoiler up mode).
My GTR requires three push and holds (RRR mode)
My prior BMW M's all required a M button push... the list goes on.
Old Feb 18, 2012 | 02:25 PM
pdaplaya's Avatar
2012 CLS 63 AMG, 2009 Aston Martin Vantage, 1968 Camaro, 2003 GSXR-1000, 2007 Yamaha R1
You will have to program your AMG button with your preferred settings. Then after you start the car, hit the AMG button and all your presets will enable. There is no default way to turn start/stop off.
Old Feb 18, 2012 | 08:02 PM
vdubpower's Avatar
i drive them all, fast and hard
whats wierd is when i do decide to leave it on, initially it says it start stop inactive and even after a few stops it continues to stay inactive, i dont know what the criteria is for it to goto active stage
Old Feb 18, 2012 | 09:10 PM
mainly's Avatar
Porsche 991 GT3, 2012 cls63 Kleemann K3
12 mpg?
I hope your joking.
Old Feb 18, 2012 | 10:10 PM
freedom88's Avatar
Cayenne S
Standard equipment is the stop/start function: it is permanently active in the transmission's Controlled Efficiency ("C") mode, and switches the eight-cylinder engine off when the car comes to a stop. At the same time, "C" mode also means a "soft" accelerator response set-up with convenient and early gearshifts; moving off generally takes place in second gear. A green "ECO" symbol in the AMG instrument cluster shows the driver that the stop/start function is active.
The engine and transmission come across as much more agile in the "S" (Sport), "S+" (Sport plus) and "M" (Manual) modes; in addition, the stop/start function is switched off. In "S" and "M" modes, the engine management system partially suppresses the cylinders: interrupting ignition and injection under full load leads to even faster gearshifts than before. The highly emotional vocals are an appealing side effect of this lightning-fast process.
Old Feb 18, 2012 | 11:36 PM
Khamis63's Avatar
SL63 CLS63 GTR33 Escalade
The only way you can stop this feature is not to wear your seat belt, i was annoyed like you before but i found out that if you dont wear your seat belt it wont work
try it and let me know
Old Feb 19, 2012 | 01:18 AM
vdubpower's Avatar
that like makes no sense,
Old Feb 19, 2012 | 01:34 AM
Khamis63's Avatar
give it a shot nthin 2 lose mate !!
Old Feb 19, 2012 | 03:52 AM
freefall's Avatar
Originally Posted by mainly
12 mpg?
I hope your joking.
The posted MPG is 14/20 I believe. I'm mostly in stop and go stuff and I drive hard but I think I average in the 12-14 range.
Old Feb 19, 2012 | 03:54 AM
freefall's Avatar
I hear you all on the AMG button or you can just set it to S or S+ BUT the MB guy told me its important to warm it up to 180 before you messing with the setting. Is that not true?
Old Feb 19, 2012 | 03:56 AM
freefall's Avatar
So what is your overall favorite setting for sound and quickness? Im hearing RS is not the best way to get off the line.
Old Feb 19, 2012 | 07:02 AM
mainly's Avatar
this is what I found...
Mercedes-Benz says EPA fuel economy estimates with the AMG Speedshift MCT seven-speed transmission are 16 mpg in city driving and 21 mpg on the highway for both versions of the biturbo 5.5-liter V8.
Old Feb 20, 2012 | 08:49 AM
AMGLAB's Avatar
2012 CLS63
My 2006 CLS 55 averaged 14.7 mpg through 60,000 miles. So far,with 7500 miles, my 12 CLS 63 averages 15 mpg. I don't think the eco start/stop has any thing to do with the small improvement, rather it is probably the change from a 5 speed transmission to a 7 speed.
I find the eco start/stop to be an annoying gimmick. It has to shorten the life of both the starter and battery. If tuners can reprogram the ecu, it would seem to be easier to create a program to permenantly kill this stupid function.
I'd pay good money for that!
Old Feb 20, 2012 | 10:26 AM
oliver@velosdesignwerks.com's Avatar
Former Vendor of MBWorld
AMG
As stated the AMG button programming is the readily available option..
Old Feb 20, 2012 | 10:38 AM
Omni's Avatar
cls63
A simple relay switch can take care of this. As soon as engine starts the relay could be used to trigger the AMG button. No need for programing, need a relay with a 1 or 2 second delay IMO nothing more and the wiring would be pretty straight forward.
Old Feb 20, 2012 | 10:57 AM
Saeedg48's Avatar
2009 CLS63 AMG
well said!!!
