C218 CLS63, 2011 - 2019
M157 intercooler system updated
Rating: Thread Rating: 2 votes, 5.00 average.
Old Nov 17, 2014 | 09:47 AM
alexdou111's Avatar
DESIGNO CLS 63 AMG 2012
thanks for sharing the information!
so if i got the pump plus the two parts, some rubber hose and Y connector.
can you say anything about the installation process itself?
where did you mount A 278 200 03 85 ?
any pictures maybe even? thank you so much for some elaboration!
Old Nov 17, 2014 | 10:14 AM
Goletiani's Avatar
2012 CLS63AMG Kleemann K3
where did you month A 278 200 03 85 ?
Here you go. The reservoir must be mounter between the air filter boxes right in front of the Engine control Unit.
Old Nov 17, 2014 | 10:34 AM
alexdou111's Avatar
cool! thank you.
you noticed any differences ?
Old Nov 18, 2014 | 09:11 AM
Goletiani's Avatar
well there is no Horse Power gain but that upgrade keeps the temperature cold for long time which is good during summer or racing.
Old Nov 18, 2014 | 09:31 AM
alexdou111's Avatar
thanks for the info - silly question but does the reservoir fit under the engin cover?
I have a carbon fiber engine cover - look slike i'd need to drill a hole?
and about the install, when you do it, you drained the cooling fluid completely?
a few words, basically anything you'd like to share on the install process is greatly appreciated.
thanks!
Old Nov 18, 2014 | 10:00 AM
Goletiani's Avatar
The reservoir fits perfectly under the engine cover without any problems.
No, you don't have to drill or make a hole. You just remove the engine cover fill the reservoir up and that's it. When you install the reservoir you may have to check and refill couple of time until the whole system is filled with fluid.
I didn't drain the whole system, no need to do that.
For the installation of this product at least two people are needed (for taking the bumper off)
use a lift while installation.
The front bumper has to be taken off to gain access to the hoses. take off the turbo coolers to gain more working space. Everything else must be done according to the diagrams that I've posted before. Collect all escaping coolant. Before assembly check for leaks. then install the front bumper.
Old Nov 18, 2014 | 11:03 AM
  #32
alexdou111's Avatar
thanks man, really kind!
Old Nov 19, 2014 | 06:56 PM
  #33
alexdou111's Avatar
one more thing if I may,
what the following for exactly:
3. Some rubberhose and a Y-connector.
can anyone explain some on how this is needed to be done with this install ?
thank you!
Old Nov 24, 2014 | 04:04 AM
  #34
tbal's Avatar
Haters crazy
Originally Posted by Goletiani
I finally did the upgrade according to the diagrams that I posted above. On the top of splitting the system I also upgraded the inter-cooler pump. I managed to find out from the other threats that Renntech is using Pierburg CWA100.2 pump, therefore I got the pump for much lower price.
Alternatively you can also order the pump from your local MB dealer with the following part number: Mercedes SLS cooling pump Part number: A 000 500 04 86 which costs around 400USD.
Connection of wires: Zero: Ground, 3 and four: Positive pole (+)
nice info! Any advantages of just upgrading the pump? Is that what renntech does, or do they add an extra res?
Old Sep 3, 2015 | 08:09 AM
  #35
Goletiani's Avatar
First, I divorced the system and got better outcome since I live in Tbilisi, Georgia where temperature reaches 45 Degrees. For daily driver it's a very good solution and necessary if you have a modified car.
If you modify your ECU and add large turbochargers. You must add heat exchanger. I got mine from Weistec... Intake temperatures are low and stable even after hardcore racing.
Old Oct 12, 2015 | 02:42 PM
  #36
JoeNobody's Avatar
Mercedes
Is the coolant line 2782000385 absolutely required? Does it have a special connector, or would regular coolant line also fit?
I ask because I may use this same reservoir to divorce the intercooler on my E55.
Old Jan 5, 2017 | 09:17 PM
  #37
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Gonna get on this. Anyone know what size hose and Y connecter?
Old Aug 16, 2017 | 08:04 PM
  #38
6speeddave's Avatar
MB
Bumping this, those two diagrams posted look vastly different. Curious if any 2012-13 guys have done this successfully and can supply a parts list.
Old Aug 18, 2017 | 06:40 PM
  #39
KLR CLS's Avatar
CLS63 PP
I've done this in the most complete way using all the correct parts. I'll get an update soon with parts and process.
Old Aug 18, 2017 | 07:00 PM
  #40
compaddict's Avatar
2016 S63, 2013 SL63
2011 S63 also?
Vince
Old Aug 18, 2017 | 07:41 PM
  #41
amgboy916's Avatar
2012 CLS 63
can i get a ballpark estimate how much the whole conversion should cost? deciding if I should do it right away or not
Old Aug 18, 2017 | 10:17 PM
  #42
KLR CLS's Avatar
CLS63 PP
Want to say about $500cdn
Old Sep 1, 2017 | 01:02 AM
  #43
6speeddave's Avatar
MB
Peter, any chance you heard back from your mechanic on the split cooling upgrade info?
Old Sep 4, 2017 | 09:45 PM
  #44
KLR CLS's Avatar
CLS63 PP
Posted a DIY in the W212 Forum:
https://mbworld.org/forums/w212-amg/...r-circuit.html
Old Jul 22, 2019 | 05:36 PM
  #45
Daniel Gulinski's Avatar
e63amg
Hi, i have a quastion, i wanto to buy this Core :
https://www.airtecmotorsport.com/pro...ooler-upgrade/
And instal to my car E63s w212 , and i buy too water pump A0005000486.
Now i have similar setup "renntech"
Anyone khnow how install now this parts?
Here is my suggestion.
Old Aug 24, 2019 | 05:27 AM
  #46
NAPARM's Avatar
C63 AMG
Hi guys, does anyone know what month/year they moved to the improved intercooler system?
Old Dec 22, 2020 | 01:28 AM
  #47
SAMzE63s's Avatar
E63s
Anyone have an intercooler cooling diagram for 2014+ W218 similar to the one below?
interested in seeing how the plumbing goes from the intercooler to the heat exchanger to the auxiliary heat exchanger.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
