Downpipes/Exhaust
have any of you use aftermarket downpipes?? what is the best exhaust you think for the cls63?
cuz i dont like resonator delete that much, because its just too much for me...
cheers bruu
in terms of sound, which one is better, 200 cells or no cats?
what do you think about a combination of resonator delete + no cats DPs? Do you think it will create too much droning?
and one last question, did you change your spark plugs to racing spark plugs?
Thanks Freefall!
CEL went on after about 30 miles of having the DPs and I was tracking it the next day. We called Renntech and they told me that we need to retune so we put the stock pipes back on. There were no problems at the track.
Yes...from what I heard. The advice I got was cats + res delete or no cats and keep the res. I love the sound of the res delete+DPs with cats....its perfect and legal in CA.
Nope...I had a plug go at about 3000 miles and it was fixed under warrantee and this was after my tune. I've tracked it several times since with no issues.
Thanks Freefall!
is it better to throw cat and res delete, or vice versa? i know turbo hates back pressure...
is it possible to do mod on the stock resonator to reduce back pressure, because i have an idea,
if we look inside the stock resonator there it is actually H-pipe.... make a hole in the middle of it..
is it possible to close that hole so it is like resonator with "straight pipe" inside the resonator?
