For Sale- kw3 lowering kit
I purchased this kit from vividracing and used it for about a yr before trading my car in. I have the two front coilovers/sleeves and the two links for the rear. Perfect condition. $700 OBO.
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Administrator
Hyperion's Candy-Coated 4 x 4
I had the sleeve kit on my car and loved it. I wouldn't call anything I do assault. Unless you count that one time Vic and I went camping in the woods and the heat in our cabin went out, and we had to huddle together for heat.
Administrator
I hate your mummy bag
Administrator
- Give us any chance, we'll take it...give us any rule, we'll break it....
Administrator
I wasnt sure if Pert was serious or not but Ill answer:
The kit is the same for the CLS and the E63- I used the same part numbers for my E63 and CLS63.
To the OP sorry for muddying it up here- let me know if you want me to clean it up. You did get a bunch of bumps to the top no doubt
Vic: I see many options out there to lower the CLS. How would you rate this kit? What is the difference with all of them and how does the kit interface with the airmatic?
Sorry for the newb questions. I do not want to substantially affect the quality of the ride but looking to lower the car when I get new wheels.
Administrator
Haaaaaaa I kid- but I have posted on this alot actually. The KW's are tremendous. Their sleeve with progressive springs have the best spring rate set up Ive found for the front (you cant do the rear of course). The rates create a very reasonable compression and rebound with basic undulations while a more stiff feel at speed and into higher speed turns and bends. I liken the springs to stiffer when needed and softer when needed than the stock steel ones. The best part is the ability to adjust the height to what YOU want vs being stuck with a fixed height.
You can go with H&R too but they dont have ride height adjustment or the spring rates associated with the KW's. If I get another M157 with fatmatic in the rear and springs in the front Ill get the KW's all over again.
Administrator
Man do you read my posts for the past two years?
The rears are adjustable via the airmatic system- you can either spend a lot and get a module or use links. The module will allow to raise it and lower at will, the links will allow you to set it but it takes more work to adjust it.
There is no KW part for the rear- the kit comes with an adapter which you use to replace the rear stock link and it will bring the car down. For some its too much and others its not enough. For my CLS it wasnt enough so we made a quick adjustment to lower the car more to level out with the front. For the E- the link lowered the rear too much so again we adjusted it to level it out with the front.
how does one get the module? is that a Mercs direct part
i think thats what the weistec guys were telling me about then at Merc madness how they lowered their car with their own design front spring and the rear just followed to the proper height....
what was interesting is that they were running M5 size stock tires on the car, which is over 3% change in overall diameter to our stock....looked great..but dont knwo what issues that may have......for another thread
