Brake Upgrade?
Comparing to steel OE adaptor for 390mm rotor (C63 Black series):
OE caliper w/360mm rotor adaptor (C63)
OE caliper with RB adaptor for 390mm rotor (for CLS400/CLS 550 spindle fitment).
but if you need to upgrade it, then you can go with "55K's" or "63's" brakes..
-;ZAYED;-
"W219 Cls55 or Cls63" Rear calipers should bolt on.
-;ZAYED;-
Which rotors are you using?
Who did your adapter for the Calipers?
Could you produce a set for me?
Do you have the possibility to let them make a set of these adapters?
Is your car a 4-Matic?
My friend would give me his C63 Calipers for free, so it would be cool to upgrade the front brakes. But nobody has adapters and the correct rotos. 🙈
Is it plug n play with these adapters? Did he knows everything about the messurements?
I don't understand, why RB is not responding to me. Last night I found a guy in Latvia, who builds a lot for MB Cars but mostly for G-Wagons. The site is called: www.tro-nik.com. and he told me, that he has a adapter for 390x36mm setup with BREMBO 09.9313.33. I think, it would be very nice to know for all the guys here in MBWorld, where they can buy such adapters. That's why I'm sharing these infos.
