2014 CLS63 AMG S Feels Slow
I don't have a Racelogic box so I'm curious to hear your ideas on getting some objective data or things to check for functionality. I considered using the built in lap timer and just trying to press lap upon hitting 60... As far as I know these cars don't have built-in 0-60.
Also for the best launch experience you could try race start
Are you riding in S+?
I haven't launched the car, I am just referring to general driving when you put the throttle down. The downshift is sluggish and the put-your-***-back-in-the-seat thing doesn't really happen, even at low speeds. It does eventually get going but it seems slow to do so. Reminds me of old Cadillacs! Instead of a BAM here we go, it's more like, whoooooshhhhhhhhh now we're going (5 sec later).
I drive around in C but when I want to have fun I always slide the toggle over to S+. Maybe I baby the car too much. I'll try the TCU reset and driving it a bit harder.
EDIT: For anyone else looking for the trans reset:
1) foot off the brake during the whole procedure
2) press the Keyless Go Start button once
3) press the accelerator to the floor and hold for 5 seconds
4) press the Keyless Go Start button twice to turn off the ignition
5) release the gas pedal
6) Wait at least two minutes before starting the car.
The Keyless Go Start button does come out of the ignition switch - it may be a little hard to get out but I was able to pop mine out with a little effort. Then follow the normal procedure:
1) ignition switch to position 1
2) push the gas pedal to the floor and hold for 5 seconds
3) turn the ignition switch to the off (0) position
4) release the gas pedal
5) wait at least two minutes before starting the car.
Performed the reset today and drove about 5 miles (not too far). It seems about 50% more responsive although there is still some sluggishness as previously mentioned. May just be the way the natural behavior of the transmission. The issue is general sluggish transmission response unless you really floor it - the accelerator pedal seems to have no difference in response from between 5-40% throttle. After that it usually kicks hard but that is not always desirable. Until nearly halfway of pedal depression, nobody is home. Perhaps I am still getting the pedal feel for the car but my findings are that the trans is reluctant to respond unless you are flooring it.
I will continue to monitor.
You are describing a well known characteristic of the throttle and relationship with the mct
You want more oomph, just down shift with the paddle simple. It will change the throttle feel as you describe it, as you are most likely in a higher gear, which will have a lot more sluggish feel to it as you described.
Example you are cruising at 40 in 6th gear. Of course you will heave a semi sluggish peddle, as you are driving in a semi eco fuel saving setting and out of power band. especially in C mode
either down shift a few times to get what your looking for by clicking the shifter a few times, or hold it and it will give you the most optimal gear for power
Having this car for a few days now, makes me really appreciate the little things I took for granted on the Benz. For example, if the Audi is on, and you wanted to put something in the trunk, you cannot use the key, or the latch... You have to physically walk back to drivers side and push the button. Volume button is so sensitive, camera quality is horrid, no safety tech like lane assist, or distronic. Engine noise is also not so nice, needs more oomph.
The transmissions is AMAZING. The HK stereo is leaps and bounds better than the CLS.
@Pumpkinate - tuning is out of the question for me. I'm not in a position to potentially eat exorbitant repair bills because I voided the warranty. Been there, done that, not again! These cars are just too expensive to have done on them. I lack the time and mechanical know-how to do the work myself.
I don't have a Racelogic box so I'm curious to hear your ideas on getting some objective data or things to check for functionality. I considered using the built in lap timer and just trying to press lap upon hitting 60... As far as I know these cars don't have built-in 0-60.[/QUOTE
These are the things that I noticed about my CLS63 2014 with Renntech R1 pkg. The (3x) problems are the acceleration, the TCU, and the cooling. Even with my ECU upgrade the transmission shifting and power is addressed but the other problems remain.I'm investing in a pedal box MOD and water methanol MOD to remedy this. The result will be consistant performance without heat soaking and instant gratification at the gas pedal. If you are tracking like me you don't have time to be messing around with the launch control system. It takes an act of congress to engage which is unpractical for its functionality. I have a gang of power that can't be applied properly to the ground because of poor engineering and programming of the ECU. I actually shouldn't say that because MB put these settings in place as a fail safe to protect the transmission from applying 600+ lbs of torque and 600+ hp to the tranny.
