C218 CLS63, 2011 - 2019
Brake Job?
Old Mar 2, 2017 | 06:02 AM
amgboy916's Avatar
2012 CLS 63
Brake Job?
Really looking for cheaper brake options for my w218 cls63 i heard some people mentioning using e55 one piece rotors on the front? Does anyone know if this is possible on w218? I have the standard iron amg rotors
It seems the front rotor are most expensive can anybody recommend some cheap alternatives for front rotors?
Old Mar 2, 2017 | 01:11 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
If you still would like to use 2-pieces, go for Girodisc or RB for cheaper replacement of just the ring in the future.
Old Mar 2, 2017 | 02:08 PM
cm60k's Avatar
Yeah, 1-piece Rotors from "W216 Cl500/W219 Cls55/W211 E55/W221 S500/R230 SL55" should fit perfectly..
-;ZAYED;-
Old Mar 3, 2017 | 12:36 PM
amgboy916's Avatar
2012 CLS 63
You guys are life savers i really appreciate the help
Old Mar 4, 2017 | 03:27 AM
amgboy916's Avatar
2012 CLS 63
Just clarifying, for the 1 piece brakes are the pads the same? Or do i need w221 pads too?
Old Mar 4, 2017 | 03:33 AM
amgboy916's Avatar
2012 CLS 63
Also is it both front and rear that can be replaced by the one piece?
Old Mar 4, 2017 | 03:35 AM
Icarus747's Avatar
2004 S600
www.RockAuto.com for good prices
Old Mar 4, 2017 | 04:16 AM
cm60k's Avatar
Of course not,,
you have to use the 1-piece Rotor with your exist calipers..
-;ZAYED;-
Old Mar 4, 2017 | 04:20 AM
cm60k's Avatar
You have 2-piece Rotors at Fronts only, Rears are 1-piece Rotors..!
-;ZAYED;-
Old Jun 12, 2017 | 09:01 PM
Ginuwine's Avatar
G63 & CLS63 & A8L
So just to clarify, we can do 1 piece rotors on our w218 cls63amg from the w211 e55 amg? and use current pads and run perfectly safe and not lose too much brake performance?
Thank you very much!
Old Jun 16, 2017 | 01:43 AM
cm60k's Avatar
Yes,you can go with 1-piece Rotor from W211 E55 & use your current pads,
it's safe for sure & will lose that much brake performance,,
just prefer to get an OEM 1-piece Rotors..
-;ZAYED;-
Old Jun 16, 2017 | 02:25 AM
Ginuwine's Avatar
G63 & CLS63 & A8L
How do you think it compares with the stock 2 piece? my local shop is telling me that it might not fit. Do you guys have any suggestions?
thank you very much!
-;ZAYED;-
Old Jun 16, 2017 | 01:40 PM
cm60k's Avatar
Why they won't fit..?,
of course, 2-piece is more reliable than 1-piece & less heat range with more age for Rotor & pads,
but honestly; my friend got "09 W211 E63" with 2-piece Rotors,
he switch them with 1-piece Rotors since almost a year, without any issues..!,,
if anyone here tried that, pls. chime in, definitely will help us..
-;ZAYED;-
Old Jun 17, 2017 | 03:02 AM
Ginuwine's Avatar
G63 & CLS63 & A8L
Yes please!, thank you and if anyone else has experience, please let me know. Does anyone also happen to know the part numbers?
Thanks!
-;ZAYED;-
Old Oct 24, 2017 | 02:10 PM
amgboy916's Avatar
2012 CLS 63
Thanks!
late response but i've done it and it works 100% he was right
I dont have part number but ive been using these for daily driving, i can say the braking isnt as good of course but its really not a huge difference and honestly with the cost of brakes these are way better for normal driving if I wanted to go super ham I would throw the 2 piece on
Old Dec 14, 2017 | 11:37 PM
delirium's Avatar
C350
I am thinking about going this route as well but when i was researching, I read that the W211 1 piece front rotors are "crap" as they retain too much heat and are prone to cracking around the drilled holes. Is this true or is there a aftermarket W211 1 piece rotor that is better than the OEM? Or just go with OEM?
Old Dec 15, 2017 | 10:58 PM
LaunchPad's Avatar
2012 CLS63 PP, Renntech
Girodiscs are going to be your best bet. Using some other rotor is not a good idea if you can't afford proper maintenance you probably shouldn't own an AMG Stay safe dont jeopardize your safety for a couple hundred bucks
Old Dec 28, 2017 | 04:56 PM
delirium's Avatar
C350
on the Girodisc website they do not have an offering for 2012 CLS63, they have 2005-2006 and then 2007-2011. Do you know which discs fit a 2012 W218 CLS63? Would they be the same discs as the E63 2010 - 2014?
I tried emailing them about this but they never responded. Is their website still in operation & safe to order from?
Thanks!
Old Dec 28, 2017 | 10:25 PM
LaunchPad's Avatar
12-14 E63 rotors are the same These are also a good option http://www.racingbrake.com/RB-Two-pi.../mb-irk-21.htm
Thanks!
Old Dec 29, 2017 | 02:07 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Thanks for the referral & link.
We are shipping this front and rear combo kit regularly (In stock).
When it comes to rear rotors, not just look at the weight saving, make sure these rear rotor can keep your emergency brake like OE 1 pc so the safety is not impaired.
Old Apr 17, 2018 | 06:54 PM
delirium's Avatar
C350
I'm hearing that C63 one piece steel front rotors also fit the W218 CLS63 and cost about $120/ea.
Has anyone tried the C63 rotors? Is there any advantage of the C63 rotor over the E55 rotor?
Old Apr 18, 2018 | 03:18 AM
cm60k's Avatar
"C63 & E55" Rotors are the same, the difference in drilled pots,
and "C63" got (2) retaining screw holes, while E55 has (1) only,,
see attached..
-;ZAYED;-
Old Apr 18, 2018 | 08:05 PM
delirium's Avatar
C350
oh good to know, thank you. Do you know which year C63 front rotors are compatible? with the CLS63?
Old Apr 18, 2018 | 08:59 PM
try m3's Avatar
Top Answer: 1
M3, E55, cls63
I have both a e55 and just picked up a cls63, the brakes on my e55 suck even though they're fairly new and I've warped the rotors on that car a couple times. The CLS will need front rotors soon and I'll most likely go with the girodisc 2 piece cheaper than stock. I don't know why anyone would want to downgrade on brakes you never know when you need to stop on a dime even during normal street driving.
Old Apr 19, 2018 | 02:23 AM
cm60k's Avatar
You can go with "C63" 1-piece Rotors from "2007-2012"..
-;ZAYED;-
