Need Tuning and Mod Advice From My Brothers!
Would that still put you at 700whp on stock turbos? Seems very high, most tuners dont even come close to getting 700whp out of these tiny stock m157 turbos, its more high on the torque by far as per the design of this motor.
https://mbworld.org/forums/showthrea...5&goto=newpost
not sure where you would be at I don’t have catless Downpipes I have stock everything besides the intake, I just ordered catless turbo backing Downpipes so I’m not sure people are saying catless Downpipes can add 50-70HP so I’m not sure to be honest.
Do you have any pics of your meth install? Where are your nozzles mounted and is it a progressive system?
Cheers Jules
Progressive means that the meth starts spraying at a start boost pressure and then sprays more and more up to a maximum at your set “full” boost figure.
oh okay yes so the Meth sprays when I push the car not sure at what RPMs. Basically when I floor it the Meth comes out and I don’t have any signals that it’s spraying but I has been working I actually have to put some boost juice in today
With the meth it sounds like yours just sprays at a set parameter. That’s fine as I guess it isn’t fully mapped for the meth.
LF
