C218 CLS63, 2011 - 2019
COST SAVINGS - INCREASE TIRE LIFE
Old Mar 20, 2020 | 04:13 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Old Mar 22, 2020 | 04:31 AM
M1RAG3's Avatar
CLS550 AMG Pkg.
Originally Posted by K-Mac
if I read this correctly there is nothing for cls63 rear suspension re: camber and caster?
Old Mar 23, 2020 | 10:37 PM
K-Mac's Avatar
SPONSOR
Do manufacture both front Camber and Caster, Rear Camber (and extra Toe) kits to suit all Mercedes models.
Rear kit for CLS 63 #502226 K complete with bushing extraction tool. With current discount (25% off) $360
Old Apr 12, 2022 | 09:21 PM
haist82's Avatar
cls63 amg
Is there a better instructions(the once in the box are not clear) on how to install the front bushings kit?
Old Apr 12, 2022 | 11:22 PM
K-Mac's Avatar
SPONSOR
Hi
Have attached latest instruction sheets.
One sheet shows Front Camber adjustment kit only.
Other sheet both Camber & Caster !
See Spoiler.
Spoiler
Old Apr 13, 2022 | 07:08 PM
haist82's Avatar
cls63 amg
Hi
See Spoiler.
Spoiler
Hi, I appreciate that, but I'm looking for step by step ( with pictures would be great) installation instructions, I jacked up the car and stock bushings look nothing like k-mac that I bought( kit # 503116k).
Could you help me to understand better how it works?
Old Apr 14, 2022 | 12:38 AM
K-Mac's Avatar
SPONSOR
Hi
#503116K kit for C218 - CLS 63, 65 AMG Provides for the 1st time precise Camber and Caster adjustment.
Yesterday (above) instruction sheets you can see have now further simplified.
Other then “Existing sheet” (included with kit showing fitment for both Camber and Caster - step by step with pictures).
See spoiler below re separate sheet for Camber and also separate sheet for Caster (step by step including pics).
Spoiler
Re “stock bushings look nothing like KMAC”.
Background is last 40 or so years replacement Camber and Caster bushes was a “time consuming trial and error procedure” of pressing in a offset hole bush at a particular clock setting.
Then trialing on alignment rack and if incorrect the frustration of having to repeat procedure by disassembling / repositioning bush again !
KMAC changed all that - revolutionizing how adjustment is made. Inventing, patenting a system whereby now bush is inserted in “any offset position”.
Adjustment is now carried out accurately direct on alignment rack (under load) simply by rotating bolt head to exact alignment setting required. Holding in this position and tightening the lock nut!
Check it out - once you get your head around it. You realize the simplicity (often said “the simplest design is the best design”).
Old Apr 14, 2022 | 01:20 AM
haist82's Avatar
cls63 amg
lower control arm
lower control arm
Does this look right to you?
Old Apr 14, 2022 | 04:29 AM
K-Mac's Avatar
SPONSOR
Hi
Your pic shows RH side rear mount.
As per step ‘G’ there are ‘4’ INNER PLATES.
Pair Stamped ‘R’ (for RH side)
Pair Stamped ‘ L’ (for LH side)
So when fitted they match exactly the contour of the frame mount lips.
Pic shows RH mount has LH (‘L’ stamped) Plate (as can be seen “location tabs” do not accurately locate).
Matter of making sure Pair ‘R’ plates to RH side with ‘L’ stamped plates to LH. So tabs “accurately seat” as per step ‘G’ pic.
Old Apr 14, 2022 | 11:53 AM
haist82's Avatar
cls63 amg
Hi
Hi
Thats what I thought , but the bolt holes were not lining up....I will swap that one one though.
