C218 CLS63, 2011 - 2019
Boost problem
Old May 23, 2020 | 07:28 PM
Amgexpress1's Avatar
2012 cls63 & 2011 e63
Boost problem
Hello im having issues with my boost i wanted to see if anyone can help basically when i floor it i dont see any boost for couple seconds after i get more and more my car is tuned i tried stock file same thing no check engine light or anything its been going on for a month now
Old May 24, 2020 | 04:27 AM
kumizi's Avatar
Designo White AMG GTS
what type of car?
Old Jun 16, 2020 | 09:04 PM
Change78's Avatar
2003 clk500 2005 cl55
Had same problem it was waste gate actuator line. There was small leak easy fix.
Old Sep 18, 2020 | 01:31 AM
CerBErusM113's Avatar
2015 CLS63 S AMG
Intermittent Low Boost Codes
I had this issue as well. It would trigger a CEL in my situation P0299. I had a crack in one of the lines next to the pressure transducer. And I finally found it and replaced the U shaped connection.
It helped for a bit but boost was still inconsistent, after which I replaced the pressure transducer
(p/n - 010-153-13-28) boost switch that's connected to the turbo waste gates. This seems to have reawakened the car and it feels like it did the first day. This is the most recent part # for the transducer also.
Old Oct 27, 2020 | 11:54 AM
S63BenzO's Avatar
2013 CLS63
I ordered this swapped it out and my car wouldn't boost at all! Did you have to do anything to reset the solenoid? Its crazy af because when i look up this part on MB it says "this part will not fit your car" buuut i literally see it on my car right next to the IC reservoir.
