C218 CLS63, 2011 - 2019
CLS63 2014 RPM problem help
Old Jul 22, 2020 | 04:56 PM
Sltncls63's Avatar
Cls63 s-amg 2014
Hello,
I have CLS63 year 2014 the problem is in the rpm when i drive the car in the morning when i press the gas paddle the rpm up and down for a few seconds when it’s warm no problem at all the second problem in highway at 120km the rpm drop a little and i feel the power cut off and the same time when the rpm down in the highway i hear sound under the car (awww) for a second then the sound gone please help if anybody have same this problem before and he solved i upload video in attachment for the problem that i have
File Type: mov
Last edited by Sltncls63; Jul 22, 2020 at 05:00 PM. Reason: Add video for the problem
Old Jul 23, 2020 | 11:45 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Could be something with your ignition system, a misfire caused by bad plugs.
Old Jul 23, 2020 | 03:11 PM
Sltncls63's Avatar
Cls63 s-amg 2014
I replace all the 8 plugs with new OEM set in the dealer but still the same issue in the car
Old Nov 30, 2020 | 06:16 AM
charles311's Avatar
18” W213 E63S
Originally Posted by Sltncls63
Hello,
problem fix? Same as mine
Old Nov 30, 2020 | 07:05 AM
Sltncls63's Avatar
Cls63 s-amg 2014
No
Old Dec 2, 2020 | 01:59 PM
charles311's Avatar
18” W213 E63S
No
my garage suggest me try to clean up the throttlebody...what u have done? Keep posted
Old Dec 2, 2020 | 04:21 PM
Sltncls63's Avatar
Cls63 s-amg 2014
I try to clean the throttlebody and change the intake manifold with brand new i change all the map sensor i change all the spark plug but the problem still there 🤷‍♂️
All this job done in the dealer now i think to sell the car
Old Dec 4, 2020 | 02:58 AM
charles311's Avatar
18” W213 E63S
tks for yr info, I can forget the map sensor...
did yr car with a tune?
Old Dec 18, 2020 | 04:34 PM
Sltncls63's Avatar
Cls63 s-amg 2014
Yes my car have Tune but the problem before and after tune
Old Dec 21, 2020 | 04:32 AM
charles311's Avatar
18” W213 E63S
I am thinking is the Gas paddle issue. Because it’s only happen when press the gas to go.
Old Dec 23, 2020 | 10:10 AM
SimpleMike's Avatar
2013 CLS63 AMG
2013 CLS 63 AMG
I have a 2013 CLS63 AMG that has the same jerky issue. The issue only seems to happen when the Temp outside is below 50 degrees. After the car warms to above 60 degrees I dont seem to have the issue anymore. Not sure if you figured out a solution but would like to hear if you did. I only have 27,000 miles on the car.
Old Dec 23, 2020 | 01:59 PM
Sltncls63's Avatar
Cls63 s-amg 2014
I try to ask many people who have experience in that car they told me the problem from Wet clutch solenoid located in transmission
But i can’t say it because i didn’t replace that solenoid before in my car
Old Dec 31, 2020 | 12:22 AM
charles311's Avatar
18” W213 E63S
then we can try this.
Old Jan 14, 2021 | 09:11 AM
Sltncls63's Avatar
Cls63 s-amg 2014
https://youtu.be/IG9OZACdx3c
Any update?
Old Feb 3, 2021 | 04:30 AM
charles311's Avatar
18” W213 E63S
Any update?
Tried but problem reminds. Feel like the oil temperature problems.
