C218 CLS63, 2011 - 2019
Adding coolant
Old Nov 21, 2020 | 10:28 AM
opnwyder's Avatar
CLS63 AMG
Adding coolant
I have an "add coolant" message on the dash when I start the car. I looked in the manual and it referred me to the dealership or a website that is literally intended to confuse the reader. Is there a specific mixture of water to antifreeze that I need to add to this car?
Old Nov 21, 2020 | 01:12 PM
Gazwould's Avatar
S204 C250 CDI Sport
You'll have a large capacity of coolant , the level will be down a faction of that capacity .
Top up with water, without fear of dilution .
Old Nov 21, 2020 | 02:38 PM
threeMBs's Avatar
Only MBs - the best or nothing
Distilled water.
Old Dec 6, 2020 | 02:51 AM
AMG WORLD's Avatar
2003 E55 AMG
If you have low coolant check to see if your leaking coolant it could be a very small leak like a couple of drops.. if you do then that's a different problem you have and that's regarding your turbo coolant hose as mine did the same drove it like that for couple months till I realized I need a new hose as they heat up and a small leak happens over time. Check In the morning under motor If there's a couple of drops
