2014 CLS 63S 4matic Front Tire Wear
I put new Michelin a/s 3+ on at 18,000 miles - had local benz dealer do an alignment at the time - and most recently another alignment at 38,000 when they did the factory recall for replacement of steering gear bolts (though the repair sheet only says "toe alignment" instead of "front alignment" same thing??).
Anyway - I'm now 2,000 miles after the last alignment - only 20,000 on the tires from new and both front inside edges are completely shot.
Ignoring the split in the attached picture, to me it looks like they put too much toe or camber - and since nothing was noted on the last repair sheet I'm thinking they screwed up the alignment - because I don't see how there could be this much wear on the inside shoulder (note how high the wear is) in only the last 2K miles without the dealer having noted "uneven wear" or "will need tires soon" on the last repair order 2,000 miles ago--since dealers love to sell tires whenever they can.
I'm obviously going to immediately replace the fronts--but before I go back to them and complain about what I think was a crappy alignment and try to get them to cover the cost of a new alignment and at least 1/2 the cost of new tires, I'm wondering what most people get out of their fronts or if you typically see inside wear.
Tires are always evenly/properly inflated - and almost all highway driving. Though driven fast - this isn't my track toy and I'm not scrubbing these tires anywhere.
Did you buy these at a dealer? Did you ask about them being pro rated? MB's are heavy **** cars that eat rubber, but that wear does seen strange. Also seems like the dealer may be taking you for a ride in regards to alignment......they should hold alignment pretty well, IME anyway
This may not be a very helpful post! GL to ya!
OEM there is no Camber or Caster to resolve costly, premature edge tire wear by allowing to adjust tire contact angles, spread load more evenly. Excess edge load can also lead to higher impact, ruptured side walls.
IT IS NEW CAR INDUSTRIES BEST KEPT SECRET! IT IS ALL TO DO WITH COST CUTTING AND EVER INCREASING SPEED OF AUTO ASSEMBLY LINES.
KMAC took on the role and has the experience of “resolving OEM suspension short comings since 1964”. World’s Largest Range adjustable bushings, Arms and Strut Tops, AUDI to VOLVO.
FOR THE W218 CLS 63S 4 matic “A TOTAL SYSTEM”:
INCLUDING '3' ALTERNATE CAMBER (AND CASTER) ADJUSTER KITS FOR FRONT:
1. #503116 K $480. “LOWER ARM” kit up to 1.5 degrees (+ -) degrees Camber (and Caster). Replacing also the ‘4’ front highest wearing bushings at the same time.
Adjusting lower arms, retains clearance top of tire to outer fender when wanting to reduce inner edge wear (or when adjusting for “extra negative Camber” also increases track width!).
Other advantage of this lower arm kit is the forward facing thrust arm (Caster bushings) are Mono ball / 2 Axis. Deleting the OEM soft rubber, oil and air voided bushings, yet still allowing arms to travel through their required arc without binding, locking up.
The result is significant improvement to brake and steering response. There are available 2 Axis / spherical bearing bushings but in all out competition soon pound out. KMAC saw the need for a design breakthrough, a new generation and developed the above a design having “two and a half times” the load bearing, impact area.
2. #502916-2 L $545 (Stage 2 - STREET / RACE). 502916-3 L $545 (Stage 3 - FULL RACE).
Front replacement top strut mounts Camber and Caster adjustable. Up to 3 degrees. Adjust from engine bay.
NOTE: Combination of #1 and #2 provides “TRACK DAYS” – the adjustability to hit those corner apexes every time and go deeper into the corners with improved traction and brake response. In the pursuit of “front row of the grid lap times.
FOR THE REAR SUSPENSION:
3. #502226 K $480
Lower Arm Up to 1.5 degrees (+ -) Camber (and extra Toe) adjustable bushings. Like front, precise single wrench adjustment accurate under load, direct on alignment rack. Retaining top of tire to outer fender clearance when adjusting to reduce inner edge wear.
4. #502226 - 1 M $595 Upper Camber turnbuckle adjustable arms (including extra Toe adjustment to compensate).
Unlike other brands not soft extruded aluminum but OEM design high strength forged alloy.
5. #502628 K $480 UPRATED REAR MULTI LINK ARMS (6) – Bushing kit
Less twitch, flex, loss of traction – Especially when applying power to lane change / overtake.
OUR LONG TERM EXPERIENCE IN THE INDUSTRY SHOWS WITH KMAC BEING THE ACTUAL “INVENTORS / PATENTEE’S” OF ALL THE IMPORTANT DESIGN BREAKTHROUGHS:
· Single wrench adjustment system (Precise adjustment without the need for time consuming bush removal).
· Sliding ball joint adjustment system (now the industry standard).
· Ability to adjust Mercedes (Strut models) Upper adjustable mounts from engine bay (without time consuming need for strut removal)
