Brakes on cls55 vs 63
CLS55
It looks as if the new composite brakes will be 6 piston vs our 8 piston. there is some discussion about one system vs the other here - https://mbworld.org/forums/showthrea...iston+6-piston
I wonder if its because the rotors of the 6 piston are lighter and they can get away with 6 vs 8.... also, on the cls55 030 package are the calipers 6 or 8 piston? I wonder if the composite rotor for either the 030 or the 63 are directly compatible with the cls55 and when the time comes to service brakes, if this would be a 'cheap at the time' mod to update the car. Thoughts?
1 Post
2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Dogshine - The CLS55-030 front Rotors are 15" in Dia. and the Calipers are 8 Piston and these Calipers and the Rotors would have to be installed as a system on a CLS55 because of the larger Dia. 030 Rotors. - Bob
2003 E55 & 2014 GL550
From what I have heard....it's a new twin sliding caliper design. Finally someone DID it. Calipers sliding in from both sides.....leave it to Benz.
Must be just friggin incredible......the difference.
A new twin sliding calliper is used for the front brakes, the kind of innovation people have come to expect from AMG. This new, unique technology combines the advantages of a floating-calliper brake – lower heat transfer to the brake fluid and significantly improved ride comfort due to the way the brake pads are located – with the performance of a large fixed-calliper brake. At the rear a large sliding frame-type calliper provides the braking. Composite brake discs at the front and rear with a diameter of 390 and 365 millimetres respectively ensure the shortest stopping distances, remarkable strength and outstanding sensitivity.
Are they finally getting rid of that brake by wire system with the new CLS63? Thats what I heard .....just wanted to know what you guys heard as well.
