ran w/ my freinds M5
2005 e55
Originally Posted by E55_POWER
rbc55, have you dyno'ed your car? Your car seems aweful strong based on your experience. On the contrary my experience has been totally opposite but with more than 3 cars by 147ish from about 80MPH.
Yes, don't ask me why, but there is something funky done to the M5 after 1200 mile service...car is just different.
I've had my M6 for month and a half and feels the same as the M5 actually. Can't wait for the DC area MB guys to hit the track again...Derek, anyone?
2005 Brilliant Silver E55
Originally Posted by BlackCard
E55 POWER,
Let me know when you guys get together. I'm only about 50 miles away.
The weather sux right now, but I will try to get in touch with the other AMG guys to see if we can rent the track. Spero should have his Z06 by now I think.
rbc55, I hope you didn't take anything I said the wrong way...you won the race and that's that, not contesting it at all, nor am I going to make excuses for the M5 that you beat. You beat him and that's that.
As for never racing from 80, well I ran my M5 against my buddy's E55 (bone stock - honestly I don't think he's a good driver) from 20, 30, 60 and 80. While the outcome was always different, off the line the M just didn't have a chance. I won't go into the outcome from a 30MPH roll because I don't want you to get the impression that I'm challinging your outcome.
Too bad you're in FL, otherwise we can all meet up at Capitol Raceway and all have a great time, bunch of great folks come out.
2005 e55
Lexlyf is RIGHT and ANDREWAZ is WRONG!!
There is DEFINITELY a mandatory service for the E60 M5. They change the differential oil (from a transitional fluid to the permanent oil). They also unlock the S6 dynamic of the SMG which shifts at the fastest sequence available (neck-snapping gear changes). At some point AFTER the mandatory 1200 mile service the Launch Control (albeit a crippled one for the US market) will become available and unlocked. The unlocking procedure is done by the Service crew but the LC unlocks on its own a few hundred miles later according to a set algorithm which takes into account the driving style of the driver
#32
The M cars have a mandatory service after break in. The original oil put in the car for break in, is thicker just to break it in. M cars generally run much better with some miles put on it. Also the E60 M5 should be in P500S mode for it run its fastest, some guys still dont know this. Another thing is although BMW puts speed limiters, they only put it on the top gear, whatever speed you can hit on the lower gears is not limited. The speedometer should be off by alittle but not anyhing like 20mph.
#33
BMW FTW
They replace the oil, they check all the electrical systems, they reset the CBS ( The CBS is a monitor that makes sure everything is running good, when they replace the break in oil with the normal oil they must reset this because the new oil is different and will trip up the CBS sensor. So when people talk about resetting things they might we talking about the CBS sensor)
On my M3 I used S5 mode from day 1 and put it into S6 mode way before my 1,200 mile service....
#34
BMW FTW
#35
Originally Posted by AndrewAZ
What they do at a M5 break in service....
I believe they also changed the Diff oil on my M5 and M6 along with some programming.
I was not able to use S6 on my car...I'll admit that I didn't really look for it though.
#36
2005 e55
#37
2006 cls55 amg 2008 GL550 2011 audi R8 V10
On a interesting note I took my car in to have the windshield replaced and asked the service manager if my car had the "dreaded o2 pump recall/TSB (see e55 threads) and sure enough it did 1 month proir to me purchasing it.
Now.... i wonder if my car is "slower" than before the TSB????? I think I will have it dynoed. What should I be putting out RWHP on my car???
thanks,
-Moldy
thanks,
-Moldy
#38
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
The problem with the new M5 is that even the techs at the stealership have no idea how to drive them. Took me a few weeks before I even figured out S6 existed, and now I only ever use it to show off (it sounds like the SMG is going to shatter, but chirping the tires in every gear is just obscene).
A5 is much better for highway battles because you'll never over-rev or short shift, and the M5 is horrible to 60 and through the quarter, as previously discussed.
#39
C63
Originally Posted by ricky.agrawal
Maybe the engine might be broken in, but what about the rest of the components?
That is exactly what my service tech told me about the break in period. The engine already comes broken in from AMG, it's all the other parts (eg- tranny, gearbox, etc...) that needs to broken in.
#40
Regarding the speedometer accuracy issue - this has been covered in more detail by Car and Driver. I dug up the results:
http://www.caranddriver.com/features...r-scandal.html
Full article:
Bottom line is that they are not perfect, but they are also not off as much as people like to claim.
Full article:
