Smoked em :)
Old Jul 20, 2006 | 02:58 PM
Kevin M.'s Avatar
CLS 55
Smoked em :)
Lights that is
Thanks to Jim over at smokedlamps.com
He came through right on time, and a great job.
I wanted just a light tint on the red only...
Before
After
Old Jul 20, 2006 | 03:16 PM
Itzkirb's Avatar
Check my Sig
Nice Kev
Old Jul 20, 2006 | 04:08 PM
deniska's Avatar
'25 G550, '21 911Cab
that looks real nice on the black.. are you tinting your windows?
Old Jul 20, 2006 | 04:14 PM
Kevin M.'s Avatar
CLS 55
Thanks guys!
Yes windows are being done on Tuesday 35% all the way around
and a light tint on the front windshield as well
Old Jul 20, 2006 | 04:16 PM
elbowyeish's Avatar
SL55 AMG Black on Berry Red
looks good. so he just put tint on top of the lights right? it's not painted or smoked from inside the light casing?
art@kronen's Avatar
SL55 AMG, 2006 Range Rover Sport with Kahn Design Package
Great job Kev, niceeeeeee. Where the wifey at?
Old Jul 20, 2006 | 04:22 PM
cantdriveonly55's Avatar
2007 Alpina B7
Do you remove the taillight covers and send them off or what? How hard was it if that was the case?
Old Jul 20, 2006 | 08:16 PM
Kevin M.'s Avatar
CLS 55
Correct just the outside.
Old Jul 20, 2006 | 08:21 PM
Kevin M.'s Avatar
CLS 55
Yes I removed them and sent them to him.
You have to remove the black molding around the rear frame of the trunk,
there are a few black plastic rivit type things that pop out, once you do, that gives you access to the back of the tail light after pulling some carpet back. There are about 6 8MM nuts that hold it in place. The left side was easy, the right side was tuff because there was this air tank hiding one of the bolts. I was able to remove the bolt without moving the tank, but installing it was a different story, there are just two nuts holding this tank, once you remove it, you can easily access that side nut on the tail light.
It will take you about 45 minutes to remove then, and about the same if not longer to re-install.
Pic of the tank I'm referring to on the right side.
From the pic you can see 4 of the 6 nuts
Old Jul 21, 2006 | 01:41 AM
Heisenberg's Avatar
2020 S63 Coupe, 2006 Hummer H1 Alpha, 2018 McLaren 720S, 2022 Porsche 911 TurboS, 2022 Tesla Model X
Those look hot on your black car! I was thinking of doing mine, but decided against it as the stock lights (even the orange ones up front) look okay with the graphite paint.
Thanks for the tip on those chrome door locks. Ordered a set from Ebay for cheap and took five minutes to install them. Much nicer than the plastic mushrooms Mercedes gave us !
Old Jul 25, 2006 | 01:11 PM
Blake P's Avatar
'09 A4 S Line
Originally Posted by Kevin M.
Thanks guys!
The tails look great Kevin. Where did you take your car for the window tint? I went to US Tint and had them do 35% on the sides and 20% on the rear, with felt lining added to prevent scratching the tints. They did a great job, but charge an arm and a leg. I didn't mind paying extra to have it done right at a reputable shop, because I was less than impressed with the last tint job on my sedan.
Old Jul 25, 2006 | 01:13 PM
sprins's Avatar
G55, SLS, smart eq
Isn't your german export licence valid 'till 16 May 2006?
Old Jul 25, 2006 | 07:18 PM
Kevin M.'s Avatar
CLS 55
Haven't had the windows done yet, I have a appointment with US Tint tomorrow. He has done all of my care for the last 10 years. I usually do 35% all the way around, and we will probably do a very light tint on the front as well. Thanks for the tip on the felt lining, I will mention it to them.
See you around Blake.
Old Jul 31, 2006 | 12:23 PM
bfnnrgn's Avatar
SL65
I'm very disappointed in this thread. Here I am in the AMG forum looking a thread title of 'Smoked em' and I expected to see pictures of smoking tires...instead there's just the tail lights of a stationary car.
Old Jul 31, 2006 | 02:31 PM
Kevin M.'s Avatar
CLS 55
Sorry to disappoint, but if you want to smoke your tires I'd be more then happy to share the thread with you
